How much air in the tires?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2006, 06:54 PM   #1 (permalink)
View sirtiger's Photo Gallery
My dad bought a brand new 2006 Corolla a few months ago. He is complaining about the terrible mpg he gets. He gets about 28mpg on mix city & highway. Its not horrible but not great either.
Since he has been on a long long vaca, I've been driving his car to see what is wrong. I check for the obvious things. I think he doesn't have enuff air in the tires. It said 26 psi. which seem low.
What is the correct psi? tks.
BMW 03 540/6, 03 530ia, 00 LS400
sirtiger is offline   Reply With Quote
Old 08-23-2006, 08:09 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Round about 30psi is normal.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-23-2006, 08:10 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
yeah.. 30 to 35psi will do the job.
Old 08-23-2006, 08:31 PM   #4 (permalink)
View blueblue's Photo Gallery
Yeah that sounds a little low. Personally I put around 30- 32psi for normal street driving. I think the company recommends around 29psi.
I take it they are stock tires. Tires can affect mileage also, depending on compound, pattern and construction. Tire companies put out specific tires that will improve mileage but they dont usually handle that great.
But also consider other variables too, like is it an auto? That will affect things.
If your desperate and know a good place ( like a race prep outfit , the run of the mill crowds dont usually give a sh..t and are happy just to take your money) then check the alignment.
Also what type of fuel goes in. I found the new BP Ultra (hi-octane) fuel reduced my mileage, and I get better mileage out of 91RON... but if you're in the US then you'll have different fuel to me anyway.
You say its a new car, but it wouldnt hurt to check the plugs and make sure they arent fouled... maybe change to iridium plugs and try high performance leads... but doing that negates any fuel savings for the next 6 months!
But as a last note, be aware that cars dont usually acheive the company listed mileage anyway. You may just have got one that's at the outer end of the tolerance scale and wont work that great anyway.
Have fun!
blueblue is offline   Reply With Quote
Old 08-23-2006, 08:36 PM   #5 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
If you have the stock tires and wheel configuration, then use the recommended PSI on the sticker of the door jams. If you want better fuel economy, raise tire pressure by 3-5psi, a slightly rougher ride, but slightly better fuel economy.
Also, remember to measure the air pressure when the car is cooled down for at least 5 hours.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 08-23-2006, 09:18 PM   #6 (permalink)
yes, its an auto & stock.
I appreciate the quick ans. I will up it to 30 psi & see what happens.
Old 08-23-2006, 09:24 PM   #7 (permalink)
One other thing simple I forgot to mention... next time its in for service, make sure they check the timing. I'm not sure about your car, but sometimes retarding the timing a little can improve economy. Of course doing that will reduce the HP a little, but hey its your call. Make sure you get out of the waiting lounge and talk to the grease monkeys or the service manager. They usually know about that tech stuff and are quite happy to help out.
Old 08-23-2006, 11:31 PM   #8 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
I always keep mine at 30 duiring the summer and 32-34 duiring the winter, but what I have found is if you add about 2 psi so making it 32 psi, my milage constantly went up by almost 2mpg, but the tires did loose a lot of traction especially in tight turns, it feels like the car just wants to fishtail... but its your call
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 08-23-2006, 11:36 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
ok. 32 is the typical pressure a shop will put in your tire. It will depend on the tires you have if you change that. As long as you don't go over the MAX psi on the tire you should be fine. If you want to take the time you can mess around with the psi. Add or drop 1 or 2 and see if you like it, repeat.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-24-2006, 12:35 AM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
Can't adjust the timing on most DIS engines without engine management.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-24-2006, 05:03 PM   #11 (permalink)
View plrsgator's Photo Gallery
30-32 is about right. Check driver's door jam & it should list the tires and manufacuturer's specs. About mileage, watch how/when you use the "Cruise". Pick a speed that eliminates down-shifting. My pickup gets 2 mpg better at 70-75 than 55-60. Since RPMs are up in the torgue range and it doesn't come out of overdrive lock-up.
plrsgator is offline   Reply With Quote
Old 08-25-2006, 06:14 PM   #12 (permalink)
Also own a 2004 Sienna LE
View GoPitt68's Photo Gallery
Sounds like something's wrong...I have an '06 and get about 40 mpg and it's an automatic. But I do mostly highway driving. Not sure that tire pressure is the culprit for you.
2004 Toyota Sienna LE (Silver)
2006 Toyota Corolla S (Silver)
GoPitt68 is offline   Reply With Quote
Old 08-25-2006, 06:38 PM   #13 (permalink)
View 07Corolla's Photo Gallery
A lot of it has to do with the way you drive. Avoid quick starts and hard stops. Adding some air to the tires will help also, but may cost more in the long run with faster tire wear.
07Corolla is offline   Reply With Quote
Old 08-27-2006, 08:32 PM   #14 (permalink)
40 would be great...I live in NYC... home of the parking lot on the espressway ...I would be happy with 32-35mpg on mix driving.
Old 08-27-2006, 09:19 PM   #15 (permalink)
View Tango's Photo Gallery
This is good advice. I spoke to a BMW Engineer a long time ago. He stated to run tires at or just below the sidewall max pressure. It will give you much better mpg, and will protect you in the chance of an impact such as a pot hole. You tire will not likely blow out. Your car will give a slightly rougher ride, but it will be well worth it. The manual setting is for the smoothest ride. It is also the setting the tire makers like as your tire will wear faster. Another tidbit, the tire manufacturers build in a 10% overage factor in the ratings.
Tango is offline   Reply With Quote
Tires Feedback: Everyone please contribute. EKam Hardcore Tech and Competition 98 12-19-2006 02:05 AM
2 Tires Splitted...sucks Terriyaki General Discussion 10 07-19-2005 07:22 PM
Turbo the tercel? Flymasta K Tercel, Paseo, Starlet, and Sera Forum 19 01-30-2005 11:38 PM
Turbochargers Xenon Hardcore Tech and Competition 13 01-04-2004 08:12 PM
