Dumb brake/rotor question... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2006, 06:59 PM   #1 (permalink)
Bingo's Avatar
View Bingo's Photo Gallery
99 Corolla, 85,000+ miles.
When braking at mid to high speeds I get a "bumpy" "hesitating" feeling on the brakes. I've always done the brakes without messing with the rotors. The rotors are original and have some visible wear. Is the "bumpiness" a symptom of bad rotors ?
Thanks,
Bingo
Bingo is offline   Reply With Quote
Old 08-23-2006, 08:08 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
warped and old probably.. I'd get new ones.
Old 08-23-2006, 08:13 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Or for less than a 1/4 of the price you could get them skimmed.
Wll solve the problems (Assuming thats what the problem is) and should be done when ever you change brakepads.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-23-2006, 08:41 PM   #4 (permalink)
View blueblue's Photo Gallery
Sorry punter, but I'd go with new ones. Most of the skimmers around do a sh''t job and wont make things much better. Unless you know a really good guy at skimming! If ya do let me know
blueblue is offline   Reply With Quote
Old 08-23-2006, 10:11 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
For that year model they'll be a lot cheaper than you'd think for new ones.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-23-2006, 11:30 PM   #6 (permalink)
The TN Member
Got mine done at presicion brake and clutch (or something like that, here in pukekohe) Been fine for 10,000km + 2 full days at the track (over 500km of track use) so they work fine for me. Not really sure how you could do a bad job, its either flat or its not.
Cost me about $25 for both sides.
Old 08-24-2006, 06:42 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You can have them lathed, but it depends on how much material is left.
Old 08-24-2006, 07:49 AM   #8 (permalink)
Bingo's Avatar
Thanks guys.
I guess I'll get new ones next time.
I've heard that you still have to have new ones turned ? True or money grabbing B.S. ?
Dingo
Old 08-24-2006, 12:05 PM   #9 (permalink)
View Dicipleofthelie's Photo Gallery
my problem with turning rotors is that its always good to have s much metal as possible, so tat the rotors keep cool. when you turn them down, even a a tiny bit, they stand a better chance of cracking due to heat. which equals new ones anyway.
just my opinion.
current car: effed up AE-82 corolla
update: she spun a rod bearing... woooo
Dicipleofthelie is offline   Reply With Quote
Old 08-24-2006, 12:51 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
As long as its equal or more than the min thickness indicated on a disk, you're ok.
Old 09-05-2006, 05:52 AM   #11 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Yes! It is a good idea to get new ones surfaced. Even new ones can come from the factory with a little warpage sometimes. Most shops will put them on the lathe and check them out. If they are good they wont charge you to let you know one way or the other as long as you tell them you just want to see if they are true or warped. If they are slightly warped it would benefit you in the long run to have them shaved.
diver9000 is offline   Reply With Quote
Dumb Question Chancer Camry & Solara Lounge 3 01-23-2006 11:03 AM
Dumb Move 5 Speed Camry Camry & Solara Lounge 9 12-19-2005 03:22 PM
Dumb Question, What does SR5 mean? currentsupply 2nd Generation (2005+) 12 11-20-2005 02:56 PM
Dumb Question about rear speakers mwarner Audio, Video, and Security - Tech 6 10-12-2005 12:07 AM
dumb wheel question jtl MR2 Forum 17 07-22-2005 04:45 PM
