Drive Shaft Bolt (required maintenance) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2006, 08:23 AM   #1 (permalink)
View plrsgator's Photo Gallery
affects 05-07 Corollas, Matrixs,& Scions. ---- For the 15K/30K/etc service, the factory requires the tigthening of the "Drive Shaft Bolt". All 3 local Toyota dealers refuse to acknowledge its existance. They do not include it in their overpriced ($149-$199) 15k/30k service. However a search (WWW) found numerous Scion dealers (none local) including it in their $40-$75 service packages!! I contacted "Mother Toyota" (via email) and she reiterates the need to tighten this item and informs me to contact the "Customer Service Rep at the dealership. Duh..
Numerous other owners have asked this question and received no solution. We're NOT talking about the lug nuts, bearing nut (end of axle), but the "Drive Shaft Bolt. Can't be too hard given the Scion dealers price for the 15K packages.
HELP!!
plrsgator is offline   Reply With Quote
Old 08-25-2006, 09:21 AM   #2 (permalink)
After a search via all forums I see that many Corolla/Matrix owners are as perplexed as me. Guess i'm not the only one 'clueless'... Sounds like a job for the MYTHBUSTERS.... Just kidding. Gonna call "Mother Toyota", wait on hold 20 minutes, and just maybe... I get to talk to a technical versed individual who won't tell me to visit the local dealer... Regardless, I'll share whatever "Mother Toyota" reveals about this elusive (invisible?) bolt.
Old 08-25-2006, 10:14 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
they're probably gonna refer you to a service center. Techical support atleast in the main toyota company here sucks.
Old 08-25-2006, 08:23 PM   #4 (permalink)
Gameroom cash: $134355
might have 2 piece axles that need to be tightened.... usually 12mm bolts.... just lift the car up and tighten them....
or best yet, lift the car off, remove them, add threadlocker, and tighten....
Old 08-25-2006, 10:18 PM   #5 (permalink)
View tashirosgt's Photo Gallery
What about axel bolt = axel nut?
tashirosgt is offline   Reply With Quote
Old 08-25-2006, 10:58 PM   #6 (permalink)
maybe... but i doubt it since those are usually put down with 90-100 ft/lb and then have a crown and cotter pin put over them...
Old 08-26-2006, 12:24 AM   #7 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
I have had the 15K and the 30K performed at my deler (freeman toyota), and now looking at the invoices, not on either one of them was this performed...... is the car safe to drive???? I have a 05 S
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 08-26-2006, 12:50 AM   #8 (permalink)
View toyomoho's Photo Gallery
The online scheduled maintenance guides state to “tighten drive shaft bolt.” There seems to be some confusion on this by car owners. Are the new axle nuts crimped instead of having a cotter pin? And if so, is this the bolt (or nut)?
Old 08-26-2006, 07:15 AM   #9 (permalink)
D
Now that you have something in writing, nail 'em to the wall on why they didn't do what the factory ("Mother Toyota") requires.... If the invoices state 15k/30K maintenance then legally (???) they should have to complete the service (tighten bolt) at no charge. Depending on your poker skills (bluffing) you could threaten to report 'em to "Mother Toyota" for sub-standard perforance. I know I would. Bet'cha they'd throw in some free service to keep your lips sealed!!!
P.S. My incident report to "Mother Toyota" on this problem is 060627-000042).
Old 09-02-2006, 08:33 AM   #10 (permalink)
Mother Toyota was no help. Can't talk to a "mechanically educated person"... However, this time I got a male "service advisor" (at my selling dealer) who actually would listen (owned an 05 Corolla himself). He conferred with the technicians who ackowledge the bolt's existance but said they never found one loose and therefore never check it during routine maintenance. He offered to have mine checked (during the $24.95 20K service) and would even have their technician show it to me.. Granted I did mention that I was in contact with Corp. (Mother Toyota) and that Corp. was interested/concerned with the solution to my question/situation...
Maintenance Required Light j28vb 2nd Generation (2005+) 7 03-04-2006 10:13 PM
Adjusting drive shaft Bolt?? Mobil 1 jasontoy Archived Corolla threads 5 10-03-2004 12:17 PM
drive shaft - cv joint wbs3375 Archived Corolla threads 1 08-04-2004 08:48 AM
plz help question bout drive shaft PowerByBuddha Camry & Solara Lounge 4 05-19-2002 12:18 PM
