06 Corolla CE coilover help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2006, 12:34 PM   #1 (permalink)
View wappynoots's Photo Gallery
Whatsup guys I have a 2006 Toyota Corolla CE, it is a little high for my taste and im looking to lower it 2 inches. My friends say that coilovers are the way to go because springs will bring too much bounce to my ride.
Can someone suggest me a good coilover set that I can order and have installed on my car or does anyone have the same problem.
Thanks so much
wappynoots is offline   Reply With Quote
Old 08-26-2006, 05:26 AM   #2 (permalink)
View arens's Photo Gallery
There are lots of good aftermarket springs for the 2003+ Corollas. Tien, TRD, Eibach, B&G, Hotchkis, Progress just to name a few. I am not up to date on all of the coilover options but there is a special buy going on now at 9th gen corolla.com -- just need to remove those spaces when using that address.
arens is offline   Reply With Quote
Old 08-26-2006, 10:00 AM   #3 (permalink)
View c_green38's Photo Gallery
Best bet for coilovers is either Skunk2 or Ground Control coilover sleeves. Unless, of course, you have money for JIC FLTA2 full-thread coilovers.... only $1600!!!!!
-Chris
"Just my $.02"
-98 Corolla VE-
c_green38 is offline   Reply With Quote
Old 08-26-2006, 04:05 PM   #4 (permalink)
<3 lift
View XRS yo's Photo Gallery
Assuming you're referring to the coilovers found on ebay for 50-200 bucks, those are pretty crappy. I'd recommend any of afore mentioned springs before you get crappy coilovers. Most people are partial to Tein S-techs (which drop the car ~2.5") or H-techs (which are closers to 1.5"). Many people have run S-techs on factory shocks for 2+ years with no issues in accelerated shock wear. While I wouldnt recommend Teins (or Eibachs, TRD's, whatever) + stock shocks for track use, it should be fine for every day driving, assuming that you drive within the capabilities of your car.
Now if you're referring to *real* coilovers -- that is, the kind with the strut built in -- that would be the way to go if you were going to be doing track days, autox, etc. Real coilovers have the damper built in so when you adjust the height of the springs, the shock is adjusted to match it. (Crap coilovers are just the springs, so it over-compresses your stock struts in most cases ... since people with crap coilovers are usually stupid ricers who want to slam their car to the ground. This will result in VERY fast wear of your factory dampers) Tein makes a kit thats upwards of 1200 bucks, but is worth every penny. K-sport makes a nice kit that is comparable to Tein and is ~800 bucks on a group buy on another forum.
2005 Toyota Corolla XRS / GainesvilleRacing.com
XRS yo is offline   Reply With Quote
97 Corolla CE Replacement Struts peterng Archived Corolla threads 0 07-04-2006 11:26 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
03' Corolla CE, minor damage w/11K worth $6500? 93 Camry LE V6 Archived Corolla threads 14 11-09-2003 11:53 PM
