check engine lite - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2006, 08:10 PM   #1 (permalink)
View 93ToyCorolla's Photo Gallery
check engine lite
What is the most common cause of check engine lite on 95 corolla????
93ToyCorolla is offline   Reply With Quote
Old 08-25-2006, 08:14 PM   #2 (permalink)
check engine lite
Old 08-26-2006, 01:11 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
depends on of your car is OBD1 or OBD2, one thing that seems common is EGR flow related codes
Check if its OBD1 or 2 if its 1 then jumper the diagnostics connector and watch the engine light if its 2 you will need to use a code reader
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 08-26-2006, 02:07 AM   #4 (permalink)
View toyomoho's Photo Gallery
This of year Corolla may have a diagnostic system that does not need a special code reader. If so, you can read the code yourself.
94 Camry Check Engine Light Code: 71 Check EGR Valve laksh99 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-29-2011 07:52 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
2005 Matrix Check Engine Light? : OBDII SCanner Buying Tips? Matreks 1st Generation (2003-2008) 13 07-05-2005 11:25 PM
Check Engine Light on 98 corolla 240meowth Archived Corolla threads 0 07-24-2004 05:55 AM
Check Engine Lite rObsolete93LE Camry & Solara Lounge 0 06-19-2002 01:22 PM
