AE82 driveshaft boot replacement problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2006, 09:31 PM   #1 (permalink)
View wendyc's Photo Gallery
Question AE82 driveshaft boot replacement problem
Hi there, can anyone help me urgently please. I am trying to replace the driveshaft boot on my daughters corolla. I cant undo the driveshaft connecting bolts, is there a special trick?
There is not enough space to get your hand on the spanner, is there a special tool I need to use?
Thanks in advance
Simon
wendyc is offline   Reply With Quote
Old 08-25-2006, 10:09 PM   #2 (permalink)
View tashirosgt's Photo Gallery
I don't know what you mean by the drive shaft bolts - of course I'm only familiar with the 1990 and later Corollas. On those there is a nut on the end of half axle nearest the tire and its friction-fit on the other end into the differential. Were you talking about taking the joints that are covered by the boots apart?
tashirosgt is offline   Reply With Quote
Old 08-26-2006, 01:07 AM   #3 (permalink)
Thanks but no, its the drive shaft connection to the gear box.
Old 08-26-2006, 02:38 AM   #4 (permalink)
Thanks for your help, but the problem is that I connot undo the 6number 12mm hex heads that connect the drive shaft to the flange of the diff. There is not enough space to get a 12mm socket and ratchet in the space under the throttle bodies, and the nuts are to tight to use a ring- open end spanner that will fit into the space.Is it possible to use two long extensions on the socket and run then out into the wheel arch via the hole that the tie rod passes? or is there a factory tool that fits into the space?
Old 08-26-2006, 03:32 AM   #5 (permalink)
View toyomoho's Photo Gallery
Can you use a box type (open ring) wrench with an extension? This being a piece of pipe or another open-end wrench mated to the open end of the wrench you are using. There are box wrench tools with abbreviated handles allowing the use of extension handles. Or cut off the box end of the wrench leaving about 3 inches of handle, then use an extension handle (piece of pipe).
Old 08-26-2006, 03:52 AM   #6 (permalink)
Thanks for that, I will give it a go tomorrow.
siren replacement problem CDub LXi Audio, Video, and Security - Tech 9 10-23-2005 11:36 PM
North County Toyota of Anaheim xpeed Toyota Dealers 3 09-27-2005 10:58 AM
tie rod boot replacement??? fe519 Camry & Solara Lounge 2 01-08-2005 07:06 AM
CV Boot Replacement KILLACAMNY Camry & Solara Lounge 10 06-09-2004 06:35 AM
CV boot replacement bboylanky Camry & Solara Lounge 3 08-27-2003 01:09 AM
