How to remove 06' Radio? Please help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2006, 12:42 AM   #1 (permalink)
View todd2000's Photo Gallery
Does anyone have, or know where I can get detailed instructions on how to remove my 06' Corolla LE radio, pictures would be very helpful? I have treid once, but it feels like im going to break something so I gave up. just wan't to install an AUX adapter and don't feel like paying someone to do it, but I don't want to break my car either. Thanks
todd2000 is offline   Reply With Quote
Old 08-26-2006, 05:22 AM   #2 (permalink)
View arens's Photo Gallery
Going from memory so I hope this is right.
Pull up the plastic trim ring from around the shifter, starting from the back and working toward the front. You can leave the wires attached and just kinda lay it off to the side. Then take off the middle AC control knob and you will find a screw behind it. Remove that screw. Now you should be able to remove the big one piece trim from the radio/AC/storeage bins. Easiest to start from the bottom of that one and work you way up.
Now you should see 4 bolts holding the radio bracket in place. I used a 8" extension on the socket (10mm?) to get those out. Then the radio just slides out.
Everything goes right back together rather easily except for the antennae cable. I found it was a bit short and kinda tough to plug into the radio during installation.
arens is offline   Reply With Quote
Old 08-26-2006, 09:06 AM   #3 (permalink)
So the radio, vest assemble slide out in one piece? Or do I have to remove the vent assembly first? Or does the radio slide out, an leave the vent assembly in the dash? Thats where I had issues last time I tried, because the vet assembly wouldn't come out.
Old 08-26-2006, 09:14 AM   #4 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
vent assembly and radio is one pieve
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 08-26-2006, 09:39 AM   #5 (permalink)
I assume you can get them appart? Because im also considering replacing the radio compleatly.
Old 08-26-2006, 11:14 PM   #6 (permalink)
2005ToyotaCorollaS
USA
Yes you can, after you remove the radio and vent assembly, then there are two clips on top and two clips on bottom of radio, and also there are like 6 total retainer things (dunno the name of them) around the radio to help hold the seembly to the radio, it is really simple, once you get the radio and vent assembly out, you will see what I am talking about.... Hope that helped ya
D
Old 08-26-2006, 11:16 PM   #7 (permalink)
2005ToyotaCorollaS
also when taking out the vent/radio assembly, there are some really tough clips on top of the assembly, may have a little trouble getting them off, but if you pull out the bottom a little and them push down those whould come loose no problem.....
D
Old 08-29-2006, 03:18 AM   #8 (permalink)
If you are looking to replace with an aftermarket radio I highly recommend getting an adapter and wiring harness. It will come free with most radios from crutchfield.com. With a new radio you will also want new speakers. I ran with the stock speakers for a week while I waited for my speaker adapter to come in. The new stereo didn't really make the sound any better until I got the speakers installed.
Old 08-29-2006, 10:57 AM   #9 (permalink)
Banned
View DougDangger's Photo Gallery
be careful tho, if the bolts fall off, then will fall into the shift linkage area... it's a BITCH TO GET IT. You might want to put a rag on the bottom to catch them if they do. This was a stupid design for Toyota, in my opinion.
DougDangger is offline   Reply With Quote
Old 08-29-2006, 11:03 AM   #10 (permalink)
2005ToyotaCorollaS
Very very true, but I use a magnetic 10mm and you should be good to go, good call tho doug totally 4got that...
D
DIY Remove Headliner Gen 4 Camry Anshu 3rd & 4th Generation (1992–1996 & 1997–2001) 17 04-25-2012 11:03 AM
'06 Camry, what radio dash kit? PLS HELP jahman 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-07-2006 07:25 PM
Help Removing Dash Trim To Remove Radio On '96 Tacoma! AAroncohen2 1st Generation (1995.5–2004) 2 06-17-2005 07:02 PM
How to remove stock radio from tC? LISCION99 1st Generation (2005-2010) 8 10-19-2004 02:27 PM
