Key getting stuck. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2006, 05:56 PM   #1 (permalink)
View wingmancd's Photo Gallery
Key getting stuck.
When I'm done driving and go to take my key out, it tends to get stuck. This is something that has only started happening this week. It's been getting worse over time, and now when the key does come out it's covered in some kind of oil. It happens every time I park the car, so it's not just a one time thing. Any ideas as to what's up?
wingmancd is offline   Reply With Quote
Old 08-27-2006, 07:50 PM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
i would say the waffers in the lock cylinder are jamming up you can try to free them with some sort of oil but i would say the cylinder will seize up given a little time then you'll have to call a lock smith....
if it starts to not wanna turn and be a PITA then get it into ACC position and remove the cylinder by pushing up on the lock pin (under dash in the bottom of the aluminum housing) then pulling out BTW it will only work in the ACC position, if it gets stuck anywhere else you'll have to drill the hardened pin out of the surrounding aluminum!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 08-27-2006, 09:29 PM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Dry getting yourself some wet-lube for lock barrels. It sounds like the pins are locking up. Dont try to use WD40 or 5-56 (or similar) as this will dry up and you'll end up with the same problem in a few months.
Speak to a local locksmith and ask them what they use to lube lock barrels...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-28-2006, 12:38 AM   #4 (permalink)
View rice's Photo Gallery
dude........my key is still stuck for like.....6 months now and it's still there
rice is offline   Reply With Quote
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
Switchblade Key with remote and alarm system (including engine immobilization) autodoodad.com Supporting Vendor Sales 105 08-23-2006 11:05 PM
key stuck in ignition bisbeek 1st Generation (1998-2003) 1 08-11-2006 01:40 AM
key stuck in ignition jojopell Camry & Solara Lounge 14 10-24-2005 10:02 AM
Ignition key is stuck... annipants General Discussion 14 03-17-2005 09:23 AM
