What have you got planned?
I have two options i am looking at if the car doesnt get sold. I am tossing up between the two.
The first and my favourite, which i am sort of in the planning stages is a twincharge setup. Running a Remote-mounted Turbo on the rear end behind the Fuel tank, coupled with a TRD Supercharger with Electronic clutch running thru one-way valves so effectively only one is boosting at a time. Will need also: Low comp forged pistons (looking at 8.0:1 from the GZE, slightly bigger cams to compensate, and much bigger injectors. ST already has balanced bottom end so wont need to worry about that. Top mount intercooler for the SC (RMT wont need to be intercooled) and standalone ECU to handle both. Big project i know, but it will be unique if i can pull it off.
The second is the fairly standard mod schedule: Hi comp 11.5:1 overbored (89mm) forged pistons, aggressive cams (probably 256 or 262) along with new valve springs (.9 to 1.0 lift), new cam gears (although this will remove the VVT), angled valve job, port & polish (only cause it will be the only thing left), 250-300cc injectors and finally a standalone ECU to top it off. This way it all looks like standard equipment, but goes like buggery when you put your foot down.
Either way too, i will be ditching the old plunem in favour of a custom built direct piped CAI to incorporate the AFM. In some ways i am dreaming with the twin-charge, but it would be unique if it goes ahead...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
