Would it be possible to run a supercharger and a turbocharge at the same time? does any one know if this is a good idea. i heard some people did it on other cars but wasnt to sure if any one did it on a 03 rolla. What would be some the Pros n Cons to this?
89' Yota 2WD 3VZ-TTE With Flows, Intake, Underglow, Black Paint Job, Black rims, Dual Stereo Deck n Lotz More By Clicking here... http://www.cardomain.com/ride/437849/
how much psi can the izzy engine take? n have the izzy engines had any problems with a turbo or S/C?
anything is possible, but is it worth the trouble ? why not just upgrade to a bigger turbo/supercharger ? (pros) an advantage to doiong this is that the supercharger would feed the turbo or vise versa ? resulting in a fast spooling setup.. or u could run supercharger for low end power & turbo for top end (correct me if im wrong)
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
^^ Thats what i want mine for. Low end power in the S/C, coupled with shorter spooling times in the turbo means power the whole way thru. The other advantage is while they are running concurrently you get heaps more volume, rather than just plain boost.
The disadvantages are that it is costly, risky and sometimes troublesome. You also need a good intercooler setup to make it work properly...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
has any came up with a design on like how to turn off the S/C jsut like we turn off a/c by having a clutch on a pully? or something like dat~
ight i mich just have to take ur advice, do trd or anybody make High Proformance cams for the izzy motor
What are you starting off with ? is the motor allready built for Boost ? is it stock & you want to add boost ? or is it allready turbo'd & you wanna upgrade ?
