4age Mods..What can I kill? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2006, 11:49 PM   #1 (permalink)
View GTSTwNCaM's Photo Gallery
AE92 4age Mods..What can I kill?
I have a 4age big port red top from a 88 FWD Corolla with 3angle valve job, port and polish head... I have 82mm 10.5 forged pistons, Bore 40 over, shaved and balance crank, lightweight fidanza flywheel, and ACT Xtreme pressure clutch.
My question is what do you think I would be able to kill on the street/track or what would be my time on an 1/8th mile track? Any guesses please.. Thanks
GTSTwNCaM is offline   Reply With Quote
Old 08-29-2006, 12:55 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
How bout you do a dyno session to see what your power figures are right now, then we'll see. Other than being able to keep up with Integras, I would basically say Civics.
Old 08-29-2006, 07:02 AM   #3 (permalink)
The TN Member
View punter's Photo Gallery
What porting did you do to a big port?? The ports are already too large. So basically you have a fresh engine with a little more compression than standard.
What sort of car is it in?
Why don't you just take it to a drag stip? e-racing sucks.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-29-2006, 11:31 AM   #4 (permalink)
Well I didn't get it ported juz clean up the big ports cause I know they are already too big.
The engine is in a 88 Corolla Coupe GTS
Yea I gotta take it to the track, to see how it does. But I just wanted to know roughly wat I'm a be able to keep up to.
Wat about 95 Civic hatch with LS swap all stock? or any other car you can think of...
Old 08-29-2006, 11:34 AM   #5 (permalink)
I wish I have access to a dyno... I'm a look around. How much do you think it will cost to run it?
Old 08-29-2006, 12:53 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
well are the ports really too big? the idea with porting isn't JUST to make the ports larger but also to make the intake ports on the manifold and head match size... i would also polish them
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-29-2006, 01:01 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
With ths mods I wouldnt go bragging.
Even a 4A-F has a 3 angle valve job from the factory....not to mention a 4A-GE.
Old 08-29-2006, 02:01 PM   #8 (permalink)
Gameroom cash: $134355
yep.... and pretty much perfectly balanced ROTATING assembly...
having the crank balanced alone might have actually hindered that engines performance....
the light clutch will only help in the sense of making the revs quicker..... no power was added
Old 08-29-2006, 02:42 PM   #9 (permalink)
So pretty much you think I'm a be wasting my money and no or a little bit of performance will be added after those mods?? I don't understand... So I wouldn't be able to keep to much huh?
Old 08-29-2006, 03:54 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Truthfully... yeah, I wouldnt of touched those parts, till maybe when I've reached the point that you cant do anything else.
Only real power mod you did was the pistons, but even then 1mm wider bores arent that much bigger. Take it to a dyno and see what the power is now. Then thats a good point of starting.
Old 08-29-2006, 04:38 PM   #11 (permalink)
Vroom?
freakinbox's Avatar
the corolla isn't really about beating stuff in a straight line. They are more of a cornering car.
Old 08-29-2006, 04:47 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
cornering car eh
you gotta do alot of work to make it corner good.
Old 08-29-2006, 10:06 PM   #13 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
Id say your around 100whp, so You could hang with stock civics, integras, neons, eclipses, of the similar era.
Nothing to brag about.
My corolla handles good, but was sloppy when I first got it.
Front strut bar, rear upper and rear lower tie bar, coilovers with 1.5in drop, koni shocks and 17in wheels. It pulls .89g's according to a gtech.
As for performance.. its gets it done. Cold Air intake, Header, Downpipe, Magnaflow cat, catback mandrel bent (not really for power, but a whole igniton upgrade to ensure a safe spark).
Id say 110 whp at the MOST
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 08-29-2006, 10:36 PM   #14 (permalink)
Alright so.... if you were in this situation what would be your next mod? HKS 256 deg. Cams, mayb...or anything else... any suggestions
Old 08-29-2006, 11:00 PM   #15 (permalink)
The TN Member
Cams and a tuneable ECU will give the best back for buck on any 4age (IMO).
Installing kill switch toytrain13 Camry & Solara Lounge 2 05-04-2006 03:51 PM
in need of easy 3.0l mods sadcamry Camry & Solara Lounge 7 02-02-2006 06:33 AM
turbo timer and kill switch Fred4agte Audio, Video, and Security - Tech 1 12-22-2005 05:22 PM
4age makes mad powaaa boroEF Hardcore Tech and Competition 46 05-28-2003 10:24 AM
New kill switch idea (security) EKam Audio, Video, and Security - Tech 25 03-01-2003 07:16 AM
