Question about the Air Box - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2006, 06:38 PM   #1 (permalink)
Holier than thou
BCO Tech's Avatar
View BCO Tech's Photo Gallery
My friends Corolla has an Airbox that has A Vaccum line coming off it. And what looks like a Triangle shaped sensor. We want to put a cone filter on there and we were wondering if the vaccume line is needed at all. Because the car runs fine without it.
BCO Tech is offline   Reply With Quote
Old 08-29-2006, 07:12 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
I would use caution against getting rid of / cutting the vacuum line. You might want to cap it off for now. You can always cut it later. Just cap it off and set it aside for now, just to be safe. Do you feel any airflow out of the vacuum line?
diver9000 is offline   Reply With Quote
Old 08-29-2006, 08:44 PM   #3 (permalink)
Holier than thou
BCO Tech's Avatar
well we werent gonna cut it, we were just gonna let it sit there in the open air. There is very little or no air movment through it either. we drove the car for 20 minutes with that hose disconnected and it ran fine if not better.
Old 08-29-2006, 09:12 PM   #4 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
The vacum line is for the A/C Idle up valve. In theory, there should be no air flowing thru this when the A/C is off. When the AC is on tho, it will need to be connected to something or the engine will remain at low idle and run like a dog while the AC is on...
As for the sensor. These are the Air temp sensor, and can be left in the engine bay if need be, but is best in the line of air.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-31-2006, 11:08 PM   #5 (permalink)
Holier than thou
BCO Tech's Avatar
Ah ok....its almost winter here anyway so there is no need for AC lol thanks for the info
Air box clips broke 96_9c1 Archived Corolla threads 4 08-05-2006 02:08 PM
IAT (intake air temperature) sensor question Hamsterman Camry & Solara Lounge 16 09-13-2005 09:11 AM
Air Intake Question skybandit MR2 Forum 3 06-21-2005 11:45 PM
air box similarity between gen3 and gen4.5 Erbe 3rd & 4th Generation (1992–1996 & 1997–2001) 0 11-15-2004 11:04 AM
Air Filter Question unioncorps Archived Corolla threads 1 10-19-2004 02:35 PM
