turbo? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2006, 01:21 PM   #1 (permalink)
View 90prizmGSI's Photo Gallery
AE92 turbo?
hi. ive been thinkin about rebuilding my motor and tranny intsead of buyin a new car... besides adding forged internals and lower compression pistons what is needed to add small turbo to my smallport 4age? i dont want to make it a 300 hp monster and have the chance of blowing the motor but rather a reliable and respective 170-200 hp. would i have to change the cams? i plan on port and polishing the head but which valve angle would work best?
thanks in advance!
1990 Geo Prizm GSI: jvc KD-G710,intake
90prizmGSI is offline   Reply With Quote
Old 08-31-2006, 02:55 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You wont be able to change the valve angle, but you'd be fine with the stock valve seats.
No NA cams are good with turbo. A Garrett T03 might be what you'd be looking for, its a mid-range turbo capable of about 250hp without problems. Fuel system would have to be sorted out and forged Low comp. pistons are always a good choice.
Old 08-31-2006, 05:23 PM   #3 (permalink)
View AVANT's Photo Gallery
If I were you, since u got the awesome smallport. Buy a thicker metal headgasket to bring your compression down, then find a junkyard turbo to rebuild and go from there. Much more affordable. Then use a raising rate FPR for your fueling with some GZ injectors and you'd probably do 170hp just fine. It's not optimal, but affordable and u won't be sacrificing much reliability.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 08-31-2006, 06:03 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Using an FPR is sacrificing alot on the reliability scale and using GZE injectors, which are bigger than the stock ones so idle fueling is also whack.
Old 08-31-2006, 08:24 PM   #5 (permalink)
That's why you play with the AFM and lean it out several clicks to get proper idle. Some knowledge with this equipment and you won't see leaning situations, so it's reliability will still be there. Yes it's not perfect, but when you only need several PSI to get 170hp-200hp, the engine is already strong enough to take the slight abuse.
When i said FPR, I meant FMU like the cartech one which can adjust the desired rising ratio.
Old 09-01-2006, 02:33 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
YEah that I figured.
Whilst the 4A-GE can take some abuse, it wont take knock under boost at all.
My Official Turbo Post!!! 97camryman Camry & Solara Lounge 25 07-20-2006 04:48 PM
More boring ?'s about N/A turbo mod namr2 MR2 Forum 12 03-01-2005 01:33 AM
oil and turbo eclypz MR2 Forum 9 08-03-2004 07:15 AM
turbo gauge messed up? eclypz MR2 Forum 46 07-23-2004 11:27 PM
are the non turbo and turbo the same? blitzed95eclips MR2 Forum 3 05-01-2003 03:17 PM
