i actuall dfid the conversion on my sr5, all the mounts for the motors and such are the same, but the locks will have to be changed for the power locks, and you'll have to wire the actual plugs inside the kick panels, bcuz you have to cut a hole in the frame across from the hole from the door, so the wires can run through. i never wired the plugs, i just ran a 12v wire to the main power switch on the drivers door and wired the passenger, i have power windows. but not power locks... but i don't care either way. it's good for me, bcuz i needed to match the GTS door panels, as i swapped the SR5 interior to the GTS interior. you'll notice if you look here.
http://pic6.piczo.com/justingallant/?g=19177674&cr=6
as you can see... it's an SR5 with a GTS interior, seats, carpet, everything, except headliner, and the front two seatbelts, but w/e
