key won't turn - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2006, 06:53 PM   #1 (permalink)
View limeandcuervo's Photo Gallery
key won't turn
Hello all, new to forums. Thanks in advance for any replies. I have a 97 toyota corolla that my key will not turn in either direction. I bought this car used and have had this problem off and on but it would always turn eventually and start fine. Now it just won't turn at all. I have read what I can find online and I am confused as to what I need. Some say ignition switch but what seems more likely is an assembly (don't recall what it is called) with keys included. Anyone familiar with this problem? Thank you very much, Gary Smith.
limeandcuervo is offline   Reply With Quote
Old 09-01-2006, 07:36 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Have tried moving the steering wheel?
2007 Camry 2.4L 5M
Old 09-01-2006, 07:37 PM   #3 (permalink)
View jon_570's Photo Gallery
haha..steering lock
jon_570 is offline   Reply With Quote
Old 09-01-2006, 10:30 PM   #4 (permalink)
I am HOT? NO SHIT?
View Driver's Photo Gallery
It seems like a steering lock to me. You just move the steering a little and then rotate the key it should turn.
Driver is offline   Reply With Quote
Old 09-02-2006, 01:46 AM   #5 (permalink)
Kliddybaba!
fistofmeat's Avatar
View fistofmeat's Photo Gallery
ya, prolly the stearing wheel lock , turn the stearing wheel at the same time that you turn the key, try it both ways, if that doesn't work, then u probably need a new lock cylinder and keys
fistofmeat is offline   Reply With Quote
Old 09-02-2006, 02:03 AM   #6 (permalink)
View 94_Rolla_Guy's Photo Gallery
it sounds more like the lock part of the ignition try to get it into "ACC" if you can there is a steel pin in the underside of the aluminum lock body (need to take off lower dash under column) with it in "ACC" Push the pin in and pull the lock cylinder out now you can start it with a screwdriver until you get a new cylinder!
If you cant get it into "ACC" then you will have to drill out the pin and then pull out the cylinder PS drilling it is a total pain as its hardened steel!
to replace cylinder put in "ACC" with a screwdriver and put the cylinder in "ACC" and just push it in, done!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 09-27-2006, 06:35 PM   #7 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Absolute PITA, you will need a hardened drill bit to cut through it. Try a little graphite, it might help.
diver9000 is offline   Reply With Quote
help key won't turn in the ignition........ lifeisviewtiful Archived Corolla threads 13 09-28-2006 09:32 PM
That annoying seat belt chime Stan_06Corolla Archived Corolla threads 4 05-07-2006 11:05 AM
Flashing lights touringcamry General Discussion 9 05-04-2006 09:52 PM
Rapid clicking noise when I turn the key... mike6789 Camry & Solara Lounge 16 04-09-2006 12:44 AM
turn key twice to start car. jamesmetairie Archived Corolla threads 15 06-10-2004 04:01 AM
