fuel pump circuit opening relay - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2006, 10:53 AM   #1 (permalink)
View list's Photo Gallery
Hi, can anyone please tell me where the fuel pump circuit opening relay is located? It's a 1999 5-speed manual car, base model. The Haynes manual says it's near the driver side under the steering wheel, to the left. But I only found a cluster of fuses and stuff. I don't know which one is the relay. Fuses are labeled but not the relay I wanted. THanks.
list is offline   Reply With Quote
Old 09-04-2006, 07:45 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
I would think it is under the hood with the other relays. Ask Dr. Tweak at phoenixtuning.com.
diver9000 is offline   Reply With Quote
Old 09-04-2006, 11:59 PM   #3 (permalink)
Gameroom cash: $134355
no.... the COR is usually somewhere near the ECU...... there should be at least a couple blue wires running from/to it and the top will actually say "circuit opening relay"
though... different toyota's will have it in different locations...... from what i've heard, corolla's have them in the cab
Old 09-05-2006, 09:04 AM   #4 (permalink)
thanks
Thank you guys! I'll keep looking for it.
Old 09-06-2006, 09:44 PM   #5 (permalink)
diver9000's Avatar
When in doubt.... consult the tech manual. When in doubt and you dont have a tech manual..... call the guys in the parts dept and they will usually help you.
Old 09-06-2006, 10:06 PM   #6 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
COR is a little black relay that sits on the Dash frame supports just behind the stereo, and on the other side of the Green flasher relay. It will have some pretty hefty wires going to it too...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-08-2006, 06:43 PM   #7 (permalink)
Reporting back about COR for fuel pump... Finally got a chance to search for it. Found it on a wire socket panel quite low (near the floor) on the left-side wall of the driver's cab, all the way front, near the clutch padel. I looked for a little black relay. It just says "Relay, Toyota". Thanks guys.
92 celica GT fuel pump won't run aero92 Celica Forum 9 06-19-2006 01:36 PM
LS 400 no power to the fuel pump?? 70 140 General Lexus Discussion 2 02-04-2005 08:42 PM
Bigger injectors/ Fuel pump in 4th gen 97camryman Camry & Solara Lounge 4 11-15-2004 05:48 PM
95 camry fuel pump connection questions dwmoss 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-24-2004 12:45 PM
