1990 Corolla Fuel guage and temp guage not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2006, 01:44 AM   #1 (permalink)
View thunked's Photo Gallery
1990 Corolla when the car is turned on the fuel guage and temp guage both slowly go up all the way.. in other words they aren't correct.
Any ideas on how to fix this? I checked the fuses under the hood and they appear fine. What should I try next?
Thanks for any suggestions.
thunked is offline   Reply With Quote
Old 09-05-2006, 05:16 AM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
It sounds like the gauge is grounding out. Have you done any mods to the vehicle?
diver9000 is offline   Reply With Quote
Old 09-05-2006, 06:22 AM   #3 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
change the fuses anyway ive seen fuses that are broken but dont look it. and yea check your grounds maybe theres a drain on thos lines. sensors?
http://www.myspace.com/13833694
xrated3345 is offline   Reply With Quote
Old 09-05-2006, 07:18 PM   #4 (permalink)
No modficiations. How do I check the ground? I guess I mean - where do I check the ground.
Old 09-10-2006, 04:42 PM   #5 (permalink)
diver9000's Avatar
on the back of the guage for one. You can do a continuity check as well. If you dont know how, I would suggest you actually have someone show you from one of your local shops, or a friend that knows a bit about basic electronics.
1989 Toyota Corolla SR5 Temp Guage, Idle, ECU and more retiredat44 Archived Corolla threads 14 03-14-2006 05:43 PM
What drives engine temp guage? xmacdaddy MR2 Forum 6 02-26-2006 01:14 PM
Jumping Temp Guage Red_85_AE86 Archived Corolla threads 4 08-09-2005 04:19 PM
Temp guage stays on. andre123 Camry & Solara Lounge 1 07-18-2005 10:07 AM
temp guage magoo_16_99 Hardcore Tech and Competition 1 02-09-2005 07:17 PM
