wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2006, 05:36 PM   #1 (permalink)
View tnmk's Photo Gallery
wires
OK so, 55,000 miles. I'm assuming original wires. I plan on changing plugs soon anyway. How long are the factory wires good for? what's an economical but reliable replacement brand?
not looking for performance, just want a good running car with good mpg.
oh yea, 1993 Geo Prizm (Corolla) 1.6 L
tnmk is offline   Reply With Quote
Old 09-05-2006, 06:01 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
they're good aslong as theres no cracks, and resistance is within specs.
Old 09-05-2006, 06:08 PM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
i just changed mine out at 243k and the new ones made minimal difference so, id leave them. a great test is too wet the wires in the dark if you see blue sparks and the engine runs worse then replace them, Just dont spray them with the hose get a spray bottle or just splash a little water from a cup or something
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 09-05-2006, 06:25 PM   #4 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
You want good quality wires: Get a set of knology wires (hotwires). They are suppose to last a lifetime.
diver9000 is offline   Reply With Quote
Old 09-23-2006, 10:35 PM   #5 (permalink)
diver9000's Avatar
So what did you decide about your wires???????????
Old 09-24-2006, 04:51 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
I'd pick up a set of OEM toyota wires, they're actually the best.
Old 09-24-2006, 09:00 AM   #7 (permalink)
Considering they appear to be in good condition I'm leaving them alone.
I would be willing to do a resistance check.
What range should I be looking for? I'd be using a standard Craftsman multi meter.
Old 09-24-2006, 09:08 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
I'd say below 15ohms.
Old 09-24-2006, 02:06 PM   #9 (permalink)
diver9000's Avatar
OEM toyota wires are good, but its strictly a personal choice. Truly only a personal choice, but the knology hotwires add a few hp and they are pretty much guaranteed.
Old 09-24-2006, 03:58 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
no offense, but plugs and wires dont add hp. OEM wires are made to toyotas specs, all other "general" brands will fall short, I've had my wires from 2000 and they're still in great condition.
Old 09-24-2006, 05:28 PM   #11 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
But just like exhausts, if the engine is no longer stock... they can help.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-24-2006, 05:43 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
No they dont help at all. Only thing a spark plug does is to provide a small spark to ignite the mixture. Thats all it does, by the time power is made, the spark has long since gone. You wont get more or less hp by changing plugs. Reason you change plugs is because the electrodes wear out due to the electric arc, gap range changes, and misfires can start. Also heat ranges differ, but a colder or hotter plug will have 0% effect on hp, only reason of them is to provide a heat range necessary for normal plug operation. For example forced inducted engines have cooler plugs, because the mixture and combustion process is hotter = plugs need to cool down faster. A low compression engine will have hotter plugs, due to cooler combustion thus a cold plug will quickly get filled up with soot.
A hot plug can wreck an engine, because you can get pre-combustion with a plug that is glowing (kinda like on diesels), which leads to detonation and engine failure.
Just basic sparkplug 101, dont get onto the bandwagon and get iridium plugs, because they promise higher hp. Its false marketing.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
90 Prizm Engine Removal - the wires? tashirosgt Archived Corolla threads 6 04-20-2006 09:22 PM
plugs & wires Abyss MR2 Forum 10 08-18-2005 11:36 PM
Tercel Clock wires? Help? gezebo Tercel, Paseo, Starlet, and Sera Forum 7 01-03-2005 03:44 PM
