What gets damaged when you reverse polarity? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2006, 05:26 PM   #1 (permalink)
View cam76034's Photo Gallery
Looking at fixer upper where someone didn't know how to connect the battery. Obviously fried something cause now it won't start. Anybody have ideas what to look at replacing?
1990 vintage.
cam76034 is offline   Reply With Quote
Old 09-06-2006, 05:48 PM   #2 (permalink)
View DoubleEdgedWomb's Photo Gallery
Starter solenoid?
DoubleEdgedWomb is offline   Reply With Quote
Old 09-06-2006, 05:53 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Check the fuses first. Does it do anything. I hope ECU didnt just get fried.
Old 09-06-2006, 05:54 PM   #4 (permalink)
Yeah, that's what I was thinking was ECU. I guess that would be $$$$?
Old 09-06-2006, 06:46 PM   #5 (permalink)
View toyomoho's Photo Gallery
Might check fuses and fusible links first. As stated the ECU or any other computer in the car may be damaged, stereo system (if on at the time), alternator field polarity and regulator circuit. The relays and starter should be OK.
Do the usually investigation for a no start engine. Check for spark and fuel. A Toyota service manual would have troubleshooting data to run a no-start engine down to the ECU.
Assume the worst and price the car accordingly. Then find a parts car, or friendly junkyard to get parts a reasonable prices.
Old 09-06-2006, 10:03 PM   #6 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Anything with a diode will be fried if you reverse polarity. This includes radios, AC units, locking mechanisms, Coils, Alternator/Generator, Starter motor and more importantly the ECU. The other thing that will go is anything with an Electrolytic Capacitor (If you dont know what these are - it doesnt matter too much) as they are polarity sensitive too. This will include the Ignitor, Distributor and Starter (although i think these are sometimes a ceramic Capacitor).
Hopefully the fuses died first. But seeing as the fuses only blow when there is electricity running thru them (too much to be exact), this is probably not the case as the diodes will fry when you reverse them regardless (They are getting electron flow the wrong way). But check the fuses to start with... If they are OK, you will need to check ALL electrical components.
Good Luck finding the problem...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-07-2006, 06:53 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
^yeah, I doubt fuses have been blown, they only blow if they heat up too much (as in a short cicuit, or too much juice), but I didnt want to discourage the OP.
Old 09-07-2006, 08:50 PM   #8 (permalink)
View justin77's Photo Gallery
Check you main fuse/fusable link, or check for 12v at the fuse box. If you dont have any voltage there with the key on, you can narrow things down a great deal.
Justin
justin77 is offline   Reply With Quote
Old 09-07-2006, 10:32 PM   #9 (permalink)
Kliddybaba!
fistofmeat's Avatar
View fistofmeat's Photo Gallery
well like spud said, reversing polarity won't effect fuses, it only effects polarity dependant components like electrolytic caps and diodes, basicly, under worse case scenario, it fried all the parts in the car that have a PCB, and anything that involves more circutry that just wires and terminals. i dont understand how someone could hook the battery up the wrong way though. one of the things that you learn as almost a fact of life is that red wire goes to red wire, and black wire goes to black... almost as important to know as "don't run into the street w/o looking" :P
fistofmeat is offline   Reply With Quote
Old 09-08-2006, 09:32 AM   #10 (permalink)
View plrsgator's Photo Gallery
My neighbor did that to his Lexus. After checking all fuses (and replacing 4 of 'em) we got the car started but various electrical items (dash guages, shift solenoid, etc.) still were malfunctioning. After racking our brains for two days he took in to the dealer (it drove..). Only thing still bad was the alternator...
plrsgator is offline   Reply With Quote
Old 09-08-2006, 09:41 AM   #11 (permalink)
Doctor J's Avatar
Gameroom cash: $262890
View Doctor J's Photo Gallery
Voltage regulator and igniter. The ECU on some models has diode protection.
Doctor J is offline   Reply With Quote
Reverse Light Switch/Connection k21xfr Celica Forum 0 08-08-2006 05:00 AM
Reverse light madness! thaharlequin 3rd & 4th Generation (1992–1996 & 1997–2001) 3 07-18-2006 05:36 PM
Reverse threads on wheel studs? touringcamry General Discussion 5 09-10-2005 06:21 PM
Hard to move from Park to Reverse fruto123 Camry & Solara Lounge 13 07-12-2004 08:02 PM
No Reverse!! JSVH Camry & Solara Lounge 5 06-11-2004 11:24 PM
