Idle speed variable; due to temp? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2006, 04:52 PM   #1 (permalink)
View DarkNinja75's Photo Gallery
When I start my car up in the morning the idle is around 1300 RPM's. Today, the car had been sitting in a parking lot for a few hours, and it was about 90 outside. I noticed that the idle was way down at 500 RPM's. Does temperature cause the idle speed to change? If so, how? And if not, what could be doing it?
DarkNinja75 is offline   Reply With Quote
Old 09-07-2006, 05:11 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
Yup when you cars engine is cold it will idle significatlly higher doe to the air/gas mixture, it is normal to have higher idle RPMs when the engine is cold...
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 09-07-2006, 05:51 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Yup, you have an Idle speed control valve. It bleeds extra air around the throttle body when you car is cold. Helps it warm up quicker.
Outside temp should have little to no effect on idle speed though.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 09-07-2006, 09:16 PM   #4 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Yah, the ISC Valve will be the one that will do it. Engine Temp plays a big part in Idle speed.
Sort of Off topic: Punter - do you know where the ISCV is on the 20v? I cant seem to track it down....
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-07-2006, 09:32 PM   #5 (permalink)
The TN Member
You having Idle problems? The ISCV is under the TB's No.4 cylinder. Its a real pain to get to as the airbox + trumpets need to come off.
This photo is handy for 20v idle issues.
Old 09-07-2006, 10:32 PM   #6 (permalink)
Country Hick
thespud's Avatar
That is NOT what i wanted to hear Now i know why i cant find it.
But yeah, my idle is stuck at 1500-2000rpm, and all the vac lines are good, idle up works because if i reverse it and turn the ac on, it drops to a healthy 500, rather than going up to 1500, so all i can pinpoint is the ISCV...
Old 09-07-2006, 11:37 PM   #7 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
When I first dropped my 20v ST in my car it idled real high too. First few days the idle was about 1500. After a few days I replaced most of my vacuum lines. The idle dropped down to 1000-1100 and its been there since. That was 6 months ago. Now the only time it idles up is in the mornings when its cool outside. As it warms up the idle goes back to where its suppose to.
diver9000 is offline   Reply With Quote
Old 09-07-2006, 11:44 PM   #8 (permalink)
Country Hick
thespud's Avatar
^^ I replaced ALL of the vac lines - they are good. So they are not the problem.
Old 09-08-2006, 03:46 AM   #9 (permalink)
The TN Member
From what I've heard ISCV is a pretty common failure, just need pulling off and cleaning.
Old 09-09-2006, 05:46 PM   #10 (permalink)
diver9000's Avatar
How do you clean it, and what symptoms are displayed when its bad?
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Idle Speed valve - what is it and how does it work? pschultz Camry & Solara Lounge 1 08-27-2005 02:57 PM
idle speed control.. help! gervis01 Camry & Solara Lounge 1 08-16-2005 12:50 AM
idle speed allmine97 Camry & Solara Lounge 3 12-28-2002 06:32 PM
How to adjust idle speed (90 Camry DX I-4) adi 1st & 2nd Generation (1983–1986 & 1987-1991) 18 10-01-2002 11:31 AM
