Shifting to neutral w/out using clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2006, 08:32 PM   #1 (permalink)
View DarkNinja75's Photo Gallery
I accidentally shifted into neutral without stepping on the clutch. It was so easy I didn't realize it until after the fact. I had meant to shift to nuetral, I just shifted and hit the clutch instead of the reverse order like I should have done. I tried it intentionally, and it was as easy as the first time. I always figured it would grind. Is this bad to do, or is it just a bad habit?
DarkNinja75 is offline   Reply With Quote
Old 09-07-2006, 08:42 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
it will only grind if you try to shift INTO gear without the clutch at the wrong rpm. You can actually shift without the clutch by matching the rpm. But it's a pain, I taught myself how to do it as if anything ever happens to the clutch only think I am left trying to figure out is how ot get the car rolling first :s.
As far as I know what you did doesn't hurt the car.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-07-2006, 08:45 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Not the best habit. Won't do any real damage unless you do it every time you shift.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 09-07-2006, 08:48 PM   #4 (permalink)
The TN Member
freakinbox: just start the car in gear, I had to drive my mates car home with a snapped clutch cable. You get some strange looks at intersections stalling it, then starting it in gear.
Old 09-07-2006, 09:09 PM   #5 (permalink)
View 07Corolla's Photo Gallery
Many tractor trailer drivers shift without the clutch. Those transmissions are not syncronized and they have to double clutch them or just shift without using the clutch at all. You have to have your rpm's matched to the road speed to prevent grinding though.
07Corolla is offline   Reply With Quote
Old 09-07-2006, 09:09 PM   #6 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Just a bad habit. Pulling it out of gear wont hurt it...
punter: But what happens if your in a driveway, need to reverse and have a sticky/dodgy reverse gear like all of the C-Series boxes i have driven?
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-07-2006, 09:14 PM   #7 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
I have done that accidentaly on my last car once, and as long as your tranny is not under a load (like you pressing the accelerator or using engine brake) it should be OK, but like mentiond before would advise to do on a regular basis
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 09-07-2006, 09:15 PM   #8 (permalink)
Vroom?
freakinbox's Avatar
I have to roll mine back a bit sometimes to FULLY engage reverse otherwise it pops out. Took me a bit to figure that out, shocked my dad when he test drove the car and it did it to him.
Old 09-07-2006, 09:41 PM   #9 (permalink)
The TN Member
Just roll the car back of forth till you engage reversse then start it. Stall it after you back out, then start it in 1st.(did I actually just suggest that ) Its roundabouts that are the most challenging.
Lucky my mates car was an old van. 3 speed column change + diesel made things pretty simple.
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Clutch, Gear shifting 05 taco cchukan 2nd Generation (2005+) 12 10-19-2006 01:35 AM
Shifting to Neutral while Driving p@nda Camry & Solara Lounge 1 07-06-2006 01:26 AM
no clutch shifting 80toy Pre-88 Toyota Pickup/Hilux 8 11-28-2005 09:14 PM
shifting to neutral Xevuhtess77 General Discussion 2 03-21-2004 05:08 PM
