Door Won't Open - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2006, 01:03 PM   #1 (permalink)
View Chuy's Photo Gallery
Door Won't Open
I have an '89 Corolla, 4-door. The right rear door one day just wouldn't open. And, yes, it's unlocked. I guess I'm going to have to remove the seat and try and pop out the door panels.
Anyone have any suggestions on what I should look at?
Tnx.
Chuy is offline   Reply With Quote
Old 09-11-2006, 05:09 PM   #2 (permalink)
I Like Traffic Lights !!!
05_Echo's Avatar
View 05_Echo's Photo Gallery
Canada
Did you try pulling on the door handle? If so I'm stumped without seeing it..
My Cars, 2006 Corolla CE, 2003 Corolla LE
http://img.photobucket.com/albums/v280/Bart68/Sigs/corsig.jpg
05_Echo is online now   Reply With Quote
Old 09-11-2006, 05:26 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Probably a porblem with the lock, ie you can't unlock the door.
Just pull it apart and have a look, its all pretty simple in there.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 09-11-2006, 06:49 PM   #4 (permalink)
View Electric Pi's Photo Gallery
Do you have child locks activated? I ask because I had the outside rear door handle stop working on me in my '90 4 doors. I took the door panel part way off (Toyota needs to look at VW window cranks, they are so much easier to take off), and reached inside. There is a rod that connects the outside door handle to the latch mechanism, and it had come off the outside door handle assembly. I popped it back in, but it was clearly missing an e-clip, so it didn’t stay in very long. This would not affect the inside door handle, but there may be something equally simple that affects both the inside and outside handles. I don’t have to access the rear "seat" area very often, so I have just been using the passenger side door.
Electric Pi is offline   Reply With Quote
Old 09-12-2006, 04:08 PM   #5 (permalink)
Kliddybaba!
fistofmeat's Avatar
View fistofmeat's Photo Gallery
lmao! i had the exact same problem in my '90, same door even! the clip that holds the bar to the inside handle was broken. to fix it, remove the window handle, unbolt the latch and door handle, and slide the latch handle off (i believe you have to slite towards he front of the car) then gently pull the edges of the panel and the whole thing should pop off. then you can open the door and see which clip is broken. if it wont open from the inside or outside, then most likely the child lock is on and the outside handle clip is busted. worse case scenario (not really that bad, but whatever) both the inside handle clips and the outside handle clips are broken. just make a trip to ur local junkyard for the clips.
fistofmeat is offline   Reply With Quote
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
Please open the DOOR CAREFULLY! Rahxephon Yaris, Vitz and Echo Forum 39 07-04-2006 12:36 PM
Left rear door wont open!! PoR2GeEzCamry Camry & Solara Lounge 6 06-30-2006 07:46 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 06:04 PM
HELP! The Driver's Door Won't Open!! camrodv6 Camry & Solara Lounge 1 03-31-2004 05:25 PM
