The reason I say it won't "see" the boost is because of the different voltage output of the 2bar sensor. As far as the ECU can tell the manifold pressure never goes positive.
2 bar map sensor are 0 to 5V, 1 bar map sensors are 0 to 5V. They are just scaled differently. If a 2 bar map sensor is reading more than the 2.5V, the ECM is seeing boost. They are scaled differently that is why swapping map sensors screws the ECM up.
I know that.
I was saying it can't "see" the boost because the ECU can't tell which map sensor is plugged into it. It will be using an N/A map.
The engine in this car was put on a dyno and the FPR was adjusted until the AFR's were safe all over the rev range. There is no "blind luck".
I know this is not the ideal setup, If I wanted to turbo a 4afe this is not the path I would choose. But I don't like it when people discredit an idea when the have no experience.
I getting sick of people say that this car the have never seen runs like crap. And this tread has served its purpose for it owner, So I'll not be replying anymore.
TheOtherCarolla: Good luck, and don't write an idea off because of someone else's opinion.
Say no to huge pics as signatures.
lol dont give up on it man ! save your money & do it right
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
Its not worth hardly anything on trade in, nothing wrong with it. When I get some cash ill make it fast, but for now, its just cheaper and easier to find a dsm or another car with a stronger performance aftermarket.
Who cares about "performance aftermarket" support, when you can make your own stuff.
Sounds more like you're trying to turbo with a very low budget, yeah you can do it, but it has its risks. I'm with the others, save up and do it right.
yes save up and do it right....the most you can run with no up-grade is 5 psi....I know because i did it for awhile until i got a e-management and bigger injectors and etc.................
i dunno about you guys but i have more respect for a guy who builts a diff car (like a corolla lol ) & go out an run with the mass produced Turbo cars... imagine the looks on their cocky faces ; )
114k miles. stock crappy clutch, needs new brakes and a lot of work done to it just to make it run smooth. Why spend the money on a car with that many miles when I can just find another car already. I know these little toyotas run forever, but I just dont have the money for one right now. Give me about 10 years and ill have the fastest Geo Prizm ever
you have those issues with any other used cars.. its all up to you though so im not gunna beat it to death
YEah corolla from what i have read from this thread you will never go wrong doing it the right way. Something you do not want to run into is doing it the shorcut way blow your engine and then instead of spending 2400 for lets say Garrets aftermarket warrantied Turbo kit, you now out what 1500-2500 to find a rebuilt engine to drop in your car or maybe then better off buying a new car. But whatever you do do it right cause then you will never be wrong.
" I no longer have Bad Days only Good Days and Great Days" - Lance Armstrong
"In times of War Power is not in the Eye of the beholder but in the Heart of his men that fight for him"
" It is during our darkest moments that we must focus to see the light" - Aristotle
