Electronics problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2006, 09:06 PM   #1 (permalink)
View shsh75's Photo Gallery
Electronics problem
While inserting my radio into the slot after reconnececting some wires on my 97 corolla the was a small spark and now the radio ,digital clock and overhead light dont work but for some reason the cigarette lighter does work. I checked the fuses and there all fine. Any solutions?
shsh75 is offline   Reply With Quote
Old 09-13-2006, 09:37 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
it has to be the dome fuse all what you are describing is controlled by that fuse
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 09-13-2006, 09:52 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
You have blow a fuse, check again.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 09-13-2006, 10:08 PM   #4 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Yep, dome fuse gets my vote too. Its in the Main fuse box under the hood.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-13-2006, 10:41 PM   #5 (permalink)
u were right it was the dome fuse thanx alot. but one more question . the fuse that was blown was a 7.5 but the fuse box cover said there should be a 20 in that spot. should I replace it with a 20 or keep the same kind a 7.5???
Old 09-13-2006, 10:50 PM   #6 (permalink)
The TN Member
Doesn't really matter, either would do.
Old 09-14-2006, 08:10 AM   #7 (permalink)
2005ToyotaCorollaS
Id go with 20 if it says 20amps 7.5 is a little low for all those circuits
D
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 11:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 02:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 11:27 AM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 05:31 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 02:33 PM
