Abs Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2006, 06:45 PM   #1 (permalink)
View ABPRSX's Photo Gallery
Abs Sensor
hi everyone, new member here in need of some help.
i have a 95 corolla 1.8 w/abs automatic. i was in the midst of removing the hub assembly so i can remove the hub bearin an replace it, in the midst i tried to remove the abs sensor and broke it in doin so.. will the sensor affect anything else besides the car not havin abs? or does the sensor only send a signal to the dash?
my other question is , how do i replace the sensor? i see the wires leading up top to the fender but have no idea on how to replace this....
3 rd question is , do i have abs anymore? the abs light is on on the dash now.
thanks for your help.
ABPRSX is offline   Reply With Quote
Old 09-17-2006, 09:09 PM   #2 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
ABS will not be engaged on that wheel anymore. This sends a signal to the ABS ECU to let it know if the wheel has locked up. No signal - No ABS.
To replace it there should be a connector under the fender mud guard, so you will need to remove this to get to the connector, on the hub - it just screws off.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-18-2006, 09:21 AM   #3 (permalink)
unfor. i broke the sensor off tryin to remove it off the hub. where can i get a new one besides gettin ripped at the dealer and how much is it?
thanks spud.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 12:01 PM
