hi all,
i'm looking for instructions on how to program keyless remote with our new '07 CE with power windows/locks...if you have instructions that work plz hook me up
...is there anything i need to look for on the remote? as i am going to purchase one off of ebay
thanks ahead of time
i've done some searching here and tried these instructions, which didn't work......
1- Driveres door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a
number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programing
and
1. Start with the following conditions:
a) Key is out of the ignition
b) Driver door is open (all other doors are closed)
c) Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a)Using the power lock/unlock switch on the driver's door (with the driver's door still open and unlocked), perform 5 lock/unlock cycles starting with lock. A lock/unlock cycle consists of pressing the power lock switch, followed by pressing the power unlock switch on the driver's door panel. Use an even pace and try to go relatively fast.
b)Close, then open, the driver's door.
4. Perform these steps within 40 seconds:
a) Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock, as you did previously.
b) Turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
c) Again, turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
d) Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (lock then unlock) automatically, indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a) Press the lock and unlock buttons on the transmitter (the remote) simultaneously for 1 second.
b) Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold it for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 6a and 6b, as this means the remote has not been accepted.
c) Repeat steps 6a and 6b for each transmitter that will operate the vehicle, including any old transmitters.
7. Close driver's door.
and
1. Close all doors (make sure key is not in the ignition).
2. Open drivers’ door.
3. Insert ignition key and remove (without turning key).
4. Close and Open drivers’ door 2 times.
5. Insert ignition key and remove (without turning key).
6. Close and Open drivers’ door 2 times.
7. Insert ignition key, DO NOT remove ignition key.
8. Close drivers’ door.
9. Turn ignition key from “OFF” to “ON” 2 times.
10. Remove ignition key.
11. Locks will cycle from LOCK/UNLOCK to confirm program mode has been entered.
12. Press and release the LOCK and UNLOCK buttons (at the same time) then press and release the LOCK button on the same remote, press and release the LOCK and UNLOCK buttons (at the same time) then press and release the LOCK button on the same remote locks will cycle again to confirm remote has been programmed.
13. If you’re programming more than one remote, with any additional remote repeat step 12 now.
14. To exit program mode, open and close drivers door and test remote.
