Bleeding brakes: How's it done? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2006, 05:29 AM   #1 (permalink)
View pdrover's Photo Gallery
This is the lesson I learned over the weekend: 4 year old girls and DIY auto repair mix like oil and water!
I was replacing the brake shoes of my '97 Corolla over the weekend, and my 4 year old daughter was being an excellent tool swiper. I was getting frustrated with her for relocating all my tools, and she with me for telling her to "leave them alone!". So she asked if she could 'tend to drive. I had the rear wheel and drum off, but the car was well secured, I wasn't working under it and the steering locked, so, to keep her entertained while I worked, I said sure. I had just released the springs that hold the shoes in place when a jet of brake fluid came streaming from one of the pistons. WTF? There should be no pressure in the lines unless someone was... "Stop pressing the pedals *NOW*!"... squirt. "I said *STOP*!"... squirt. "That's it, *get out* and go bug your Mother!" ...
So now I've air in my brake cylinder. Indeed, the piston had popped right out. The air needs to be bled, but I've never bled brakes before.
I've done a search of the forum and the web, but I've not been able to get any precise information about the procedure. However, this is my understanding of what is necessary:
- I must make sure that the brake fluid is topped up.
- I must have someone fully depress the brake pedal (a certain 4yo may prove useful here)
- I must loosen (or remove?) a draining vent to allow the air to escape.
- I must then resecure the vent.
- repeat until there is no more air.
Is this correct? Where will I find the venting screw/nipple/valve? What kind of tool will I need. Will I have to bleed all four wheel?
All assistance is sincerely appreciated. The car is not safe as it is.
Thanks,
Paul.
pdrover is offline   Reply With Quote
Problem bleeding brakes on 95 Camry soonergn 3rd & 4th Generation (1992–1996 & 1997–2001) 32 01-20-2011 12:47 AM
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 04:18 AM
bleeding my brakes myungx714 Camry & Solara Lounge 5 01-30-2006 08:09 PM
help with bleeding brakes pberg Pre-88 Toyota Pickup/Hilux 10 11-08-2005 02:53 PM
Bleeding Brakes Trdkamuri510 Hardcore Tech and Competition 14 04-14-2004 09:07 PM
