2003 Fog light wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2006, 12:16 PM   #1 (permalink)
JBacka's Avatar
View JBacka's Photo Gallery
Canada 2003 Fog light wiring
Looking to add fog lights in my 03 CE. I read somewhere that the wiring 'might' already be there. Does anyone know for sure?
Thanks,
James
JBacka is offline   Reply With Quote
Old 09-19-2006, 09:39 AM   #2 (permalink)
I Like Traffic Lights !!!
05_Echo's Avatar
View 05_Echo's Photo Gallery
Canada
I just put a set I bought off Ebay and when I installed them I had to plug all the wires that came with the kit into my car, so yes some are the but you need the rest to plug in to finish the harness out to your lights and to the togle switch.
I bought this set from Ebay because I wanted the lights to fit in the stock openings in my bumper.
My Cars, 2006 Corolla CE, 2003 Corolla LE
http://img.photobucket.com/albums/v280/Bart68/Sigs/corsig.jpg
05_Echo is offline   Reply With Quote
Old 09-19-2006, 10:21 AM   #3 (permalink)
JBacka's Avatar
Thanks, that is exactly what I was looking at doing!
James
Old 09-21-2006, 05:53 AM   #4 (permalink)
View nit407's Photo Gallery
Question
I am actually planning to do the same to my 04 Corolla,CE. however, would like to know if this process was easy to do or not? How much time did it take you to fit the lights in the car? Please let me know.
thanks
nit407 is offline   Reply With Quote
Old 10-14-2006, 11:41 PM   #5 (permalink)
View leec001's Photo Gallery
Fog Light installation
I ordered one from trendgear but doesn;t fit, then from vertex racing, fits really good. Took me about 2 hours to install them. the difficult part is running a wire from fromt he inside switch to the engine bay (30 mins.)
leec001 is offline   Reply With Quote
Old 10-15-2006, 09:07 AM   #6 (permalink)
05_Echo's Avatar
Canada
thanks
It took me an hour to do the install but I have done a number of them on other cars so like the other fellow said maybe two hours.
Old 10-15-2006, 09:09 AM   #7 (permalink)
05_Echo's Avatar
Canada
The ones I got from Treandgear fit like a glove, they just popped into place and so did the toggle.
Old 10-15-2006, 10:58 PM   #8 (permalink)
View jkjk15's Photo Gallery
Canada
what are prices for the foglights you guys paid?...I'm looking to put fogs on to a 2003 Corolla LE, since one of the plastic covers has gone missing...
thanks
jkjk15 is offline   Reply With Quote
Old 10-16-2006, 10:09 AM   #9 (permalink)
05_Echo's Avatar
Canada
thanks
I got mine from Ebay and it was around 100.00 shipped to the door but I'd check Ebay and see if anyone is selling the one that you need by itself, I seen a few single lights for much less when I was looking for mine.
Old 10-17-2006, 04:49 AM   #10 (permalink)
where did you get the wirin daigram from? did it come wih the lamps?
Old 10-17-2006, 04:02 PM   #11 (permalink)
Amber's Avatar
View Amber's Photo Gallery
I did this mod a couple months after buying my '04. My brother was working for Toyota at the time and he got the lights for FREE (from NAL). He sent them to me and I wired them myself.
The wiring is behind the fog lights and runs to the fuse box (underhood). I don't remember all the details, but I ran a wire to the fuse box, use the APO (Auxillary Power Outlet) in front of the shifter for ignition switchable power, and ground somewhere under the dash, if I remember.
It was easy, all except for figuring out which wires to attach to what on the switch. :o I blew a fuse or two. :o
I pulled the little piece of plastic up from under the park brake handle (mainly because I was going to take power from the APO which is not far from there). It comes out real easy. I put a small hole there and mounted the switch. Then the trim piece that the APO is on lifts up pretty easy. I can't remember the connectors (spaid maybe) I used at the APO, but all I had to do was loosen a screw, shove the connector in and tighten the screw back. That was easy. But which wire to connect is what I had trouble with.
BTW - My fogs are independent and can be switched on any time the ignition is on ... just like the APO. No need to worry about accidently leaving the fogs on. As soon as the ignition is turned off, they go off too.
- Amber
2004 Corolla LE - 5 speed, leather, sunroof, spoiler, fog lights, alloy wheels
600 Mile Club - Founding Member
My FD - 335 hp - ~2800 lbs with me in it!
Amber is offline   Reply With Quote
Fog Light rip-off? ejctt 2nd Generation (2005+) 11 04-12-2007 01:43 PM
Wiring Help w/ ES250 Fog Light Switch phat91camryLE 1st & 2nd Generation (1983–1986 & 1987-1991) 5 08-01-2006 05:34 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 04:51 PM
taco 05 fog light PR_TACO 2nd Generation (2005+) 8 11-13-2005 01:51 AM
Fog Light Bulbs virtualkuz General Discussion 4 12-05-2004 05:53 AM
