foglights with marker lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2006, 01:48 AM   #1 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
AE92 foglights with marker lights
I am wondering how I go about wiring my foglights to make them come on with my marker lights, you know... before the headlight pop up and the lights under them come on with the tail lights.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-24-2006, 08:52 PM   #2 (permalink)
CCC-norchap
sportrally88's Avatar
View sportrally88's Photo Gallery
splice the wires together with the wiring harness to the markers
sportrally88 is offline   Reply With Quote
Old 09-24-2006, 09:30 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
yea but what wires should I splice, I really don't want to rush into my wiring and do that. Not enough power from the marker light power wire to run everything is there?
Old 09-24-2006, 09:36 PM   #4 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
Uuuuuu dont splice anything side marker light are way low current than fog lights, use a relay man just in case.
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 09-25-2006, 12:06 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
yea so I have no idea how to use a relay to make them work together LOL
Old 09-25-2006, 09:45 PM   #6 (permalink)
Kliddybaba!
fistofmeat's Avatar
View fistofmeat's Photo Gallery
it depends on how you splice them. if you splice them in a series circuit, then you'll have the same current throughout while the voltage is divided, if you splice them in a parallel circuit, then you'll have the same voltage throughout while the current gets divided. i believe that if the current stays the same, then the bulbs should stay bright (i think) so you should use a series circuit. to do this, attach the negative of the left corner to the positive of the left fog lamp, and the negative of the left fog to the positive of the left corner. then do the same thing to the right side lights. just make sure that you use the power from the fog lights and not the corners otherwise like sportrally said, both lights will be dim. that should do the trick, just keep in mind that it would require that you cut the harness' off both lamps and reattach them.
Originally Posted by REN69
OMGWTFBBQ!!! he must have typed it on his blackberry.
"Whenever cannibals are on the brink of starvation, Heaven, in its infinite mercy, sends them a fat missionary."
-Oscar Wilde
fistofmeat is offline   Reply With Quote
Old 09-30-2006, 06:25 PM   #7 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Why not add a separate switch. There are empty switch ports on the dash already, why not use one of those? You can get an illuminated or non-illuminated switch so that you can turn them on and off at your convenience. The wiring is easy to do. You can run circuit or separate switch. I would run separate switch that way you have full power and less chance or any interference.
diver9000 is offline   Reply With Quote
Old 09-30-2006, 11:45 PM   #8 (permalink)
Vroom?
freakinbox's Avatar
I have that now, screwed in at the bottom of my dash witht he supplied holder so when I remove it the holes won't be visable.
But I want to remove the fact I have to turn them on and off seperately.
Old 10-05-2006, 06:51 PM   #9 (permalink)
diver9000's Avatar
I know that if you connect the wire to the headlight fuse they will come on when the headlights come on with no loss of power. They may do the same if you find the fuse that is specific for your marker lights. I dont know if its the same fuse as the headlamp fuse. If you can connect the wiring that way at least you wont have to cut into any wires. Good Luck
Old 10-06-2006, 01:06 PM   #10 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
Well i ahve the exact same fog lights :P
All i did to achieve this is run the wire into the car, and connect it to a power wire. You can either conect it to:
Cigarette Lighter - will turn on when car is on.....good for using them as driving lights
or
Gauge lights - which wil turn on when you turn the gauge lights on (which also will turn on the marker lights
Best idea is to splice them on the cigarette lighter, but also have a switch on the power. So they will go on and off with the car and can be turned off when teh car is running.
Liter is offline   Reply With Quote
Old 10-06-2006, 07:50 PM   #11 (permalink)
diver9000's Avatar
Now that would be some funny shit.. Everytime you activate the cigarette lighter, the lights would come on, and only then.
Old 10-07-2006, 09:00 AM   #12 (permalink)
Vroom?
freakinbox's Avatar
I thought he meant the light for the cigarette lighter not the cigarette lighter itself
Old 10-08-2006, 09:16 AM   #13 (permalink)
I Like Traffic Lights !!!
05_Echo's Avatar
View 05_Echo's Photo Gallery
Canada
It's very easy and I have done it many times. You do not need a toggle for this installation and if you fallow this diagram your lights will come on with your parks and stay on when your headlights are on. If you want them to be able to turn off then you will need to run the wire lead from the positive side of your park light to a toggle in your interior so they can be turned off. With the toggle in the on position they will shut off whenever you turn your Park lights off.
If you have any other questions please feel free to email me at d_kiesman@hotmail.com and I will help you out. If I lived near you I would just come over and do it, it's a very quick and easy job.
My Cars, 2006 Corolla CE, 2003 Corolla LE
http://img.photobucket.com/albums/v280/Bart68/Sigs/corsig.jpg
05_Echo is online now   Reply With Quote
01 Sienna Front Marker lights loose blane gardner 1st Generation (1998-2003) 1 04-02-2010 01:31 PM
LED Map-Reading Lights DIY tonysun23 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-13-2006 08:05 AM
95 side marker lights - turn signal removal loomdog32 Archived Corolla threads 4 08-04-2006 09:12 PM
Problem with dash lights and DRL shadowninja General Discussion 7 04-30-2005 11:33 PM
Signal Lights / Hazard Lights problem... Z0rn Supra Forum 1 05-02-2004 04:03 PM
