Bucking under load
Hello all. I'm back with my 87 Corolla (post engine swap to 3AC). The engine runs great with 1 exception: Whenever the engine is under load such as moderate acceleration or up hills, the engine starts jerking or bucking and the performance of the engine suffers a lot. The more you step on the gas, the worse the condition gets. The car is totally drivable as long as there are no hills and you don't try to accelerate more than 20% of total capacity. (aka 0-60 in 10 min)
I've check compression, timing, and did a full tune up during the engine swap. I've checked the vacuum lines many many times and I even paid a mechanic to check the configuration of the lines.
Could a bad distributor cause this? How would I verify? Maybe the vacuum advance is messed up? The timing seems to advance when you rev the engine (verified with timing light)
Thanks!
