How often to perform a Coolant Flush - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2006, 10:17 PM   #1 (permalink)
View samp55's Photo Gallery
Hi,
I have a 2000 Toyota Corolla with about 85,000 miles on it. Within the past two years, I had a coolant flush done every year. This year the technician tells me I should get a coolant flush done. I'm wondering if it is normal for a car to have coolant flush done every year. Let me know if anyone has any info on this. Thanks in advance.
Sam
samp55 is offline   Reply With Quote
Old 09-24-2006, 10:28 PM   #2 (permalink)
Anthony
View Dakota00's Photo Gallery
If you are using the green coolant, it should be done every 2yrs/ 24,000 miles.
2000 Dakota Sport CC 4X4, 4.7V8, 5 speed, 3.55LSD. Lots of mods!!!
www.geocities.com/dak2nv/
G/F's car, 2003 Corolla LE Auto, Loaded
Dakota00 is offline   Reply With Quote
Old 09-25-2006, 01:51 AM   #3 (permalink)
View sambojoho's Photo Gallery
I go every 30k miles between coolant CHANGES, i.e. drain and refill.
I don't FLUSH the system unless I discover rust or other sediment. I think once a year is overkill, but certainly won't harm anything.
sambojoho is offline   Reply With Quote
Old 09-25-2006, 09:26 AM   #4 (permalink)
Master Taco Ninja
XxaltezzaxX's Avatar
View XxaltezzaxX's Photo Gallery
Yea two years max...............it's about time for mine
XxaltezzaxX is offline   Reply With Quote
Old 09-25-2006, 12:45 PM   #5 (permalink)
Papa Bear's Avatar
View Papa Bear's Photo Gallery
Sam, Once a year is overkill. You are just putting money in the tech's (dealer's) pocket.
You only drive about 15K a year, if you are using the everyday "green" stuff from W-M you can drain and fill every 2 years. If you are using Toyota long-life, you can drain/fill every 5 years.
No need to flush .. just drain & fill.
P.B.
Papa Bear is offline   Reply With Quote
Old 09-25-2006, 09:19 PM   #6 (permalink)
View jon_570's Photo Gallery
how do u flush the system..because theres a lil rust in mine and i know it hasnt beenn done prolly ever and it has 140000miles on it...its a 1997 toyota corolla with a 4AFE
jon_570 is offline   Reply With Quote
Old 09-25-2006, 09:25 PM   #7 (permalink)
caddymac's Avatar
View caddymac's Photo Gallery
If your car has a lot of miles, I don't think a flush would be a good idea. You could knock crud loose and force it into places that will clog the coolant passage. A simple drain and refill would be much better.
caddymac is offline   Reply With Quote
Old 09-26-2006, 11:21 AM   #8 (permalink)
View nova_insomniac's Photo Gallery
I usually get it done every other year... but I believe if they use the red fluid it's supposed to be good for a lot longer something like 4 years..
nova_insomniac is offline   Reply With Quote
Do you need to flush the coolant during the water pump change? NewRacer 3rd & 4th Generation (1992–1996 & 1997–2001) 7 09-07-2006 03:54 PM
Brand of Coolant stir_fry_boy Camry & Solara Lounge 51 01-12-2006 10:45 AM
NEED HELP: Coolant Flush laser991 Celica Forum 4 02-09-2005 09:01 PM
Coolant flush BenG Hardcore Tech and Competition 20 05-29-2004 09:27 AM
how to perform a coolant flush Trueno_Sprinter Off Topic 3 01-04-2003 01:29 AM
