Originally Posted by diver9000
I think maybe grinding a fuel pump hole in the head might have something to do with your problem.  FLASHMN where are you???
Nah, that worked fine, pump works easily, If it were binding on the arm I'd agree but I made the hole the same size as stock(the carbed engines had the hole already there, thats what the unused threaded bolt holes are from on the later year heads) Now back to what else I find (remember this was a junkyard car and it's real close to coming back to life) My MAP(?) sensor is open (at least I'm pretty sure thats it.) @ hoses coming out are connected right but the single port is open. No idea where it goes as I never saw it connected Anyone? AutoZone has pretty good vacuum diagrams for all the cars (and mentions this as MAP) but tells where the 2 go but not the single line? I can't find any open ports around intake or carb left to connect to.
