01 corolla slams into gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2006, 01:45 PM   #1 (permalink)
View sky jumper's Photo Gallery
when shifting from P to R or P to D the tranny slams into gear. once engaged it drives/shifts fine. then it slams back into P.
I noticed a second cable connected to the throttle body that is sticking. there's the main throttle cable connected to the gas pedal that is fine, and then another cable heading off the other direction that sticks - i.e. it will pull out when the throttle is depressed, but does not go back in when the throttle is lifted.
also, I noticed when viewing live OBDII data that the absolute throttle position never quite goes to 0. it does increase when the throttle is depressed, but never returns to 0. it stays at 9%. however, the car does idle at a normal 700 rpm.
I think the sticky cable somehow controls/affects the shift mechanism, but I'm not sure. does anyone have experience with this? thanks!
sky jumper is offline   Reply With Quote
'01 Corolla - oil erob Archived Corolla threads 0 07-23-2006 10:31 AM
1996 corolla shaking and changing gear problems rjousuf Archived Corolla threads 0 12-18-2005 09:22 PM
'99 corolla gear questions tmoney5 Archived Corolla threads 0 07-01-2005 12:18 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
turbo for 01 corolla s? Danelle58 Archived Corolla threads 17 06-04-2004 09:06 PM
