ae92 sr5 to gts rear brakes and front suspension. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2006, 04:04 PM   #1 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
alright so I need to know, as I have the option to buy them.
do I have to change the brake lines or anything else to put the rear calipers on it
the rear suspension isn't a problem as I would be getting the whole subframe
But the fronts... will the gts ones just bolt in place of my sr5 machpherson strut, some have told me yes, some have told me no...
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-28-2006, 04:49 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Handbrake cables and brake hoses, plus you need to change the brake bias block up in the front. They should bolt up up front.
Old 09-28-2006, 05:38 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
hmm so then thats out, as other people have claimed the handbrake cable
wonder if I could use my drum brake hubs?
Old 09-28-2006, 06:16 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
yes you can, though you have to machine them smaller, by about 1cm in diameter, so about 5mm in radius.
Get some new wires, chances are the old ones were shit anyways. my old wires snapped the first time I pulled the lever up.
Old 09-28-2006, 06:27 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
no money for that.
TO make it the easiers could I just use the machphereson rear struts and springs and shove them in there to replace the sr5 ones with no modifications?
Old 09-28-2006, 09:11 PM   #6 (permalink)
CCC-norchap
sportrally88's Avatar
View sportrally88's Photo Gallery
i have some gts front struts asymblies in the garage ....so i couldnt bolt them str8 up if i wanted?
sportrally88 is offline   Reply With Quote
Old 09-29-2006, 12:32 AM   #7 (permalink)
Vroom?
freakinbox's Avatar
well flashmn just said they will, as has ren said it. I don't see why not, they both have 3 bolt connections at the top, and 2 at the bottom.
Old 09-29-2006, 05:29 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
yes they fit vice versa.
you're planning to do a rear disk swap and you have no money for new cables, those dont even cost more than 20bucks at an autoparts store.
Secondly, depending on how old and used your calipers are, I'm not 100% sure your brakes are even gonna work, the handbrake system bearing wears out and then it wont raise the piston even though you engage the brake. Oh well good luck.
Old 09-29-2006, 05:42 AM   #9 (permalink)
Vroom?
freakinbox's Avatar
well I wasn't going to do the swap now. But the parts are avaliable. As for the suspension. that will be going on right away.
I willw ait to do the swap until I can bleed the entire break system as replacing the brake bias block will probably cause me to have to do that. Plus I will want to replace all the discs and pads. Also maybe get new calipers, since I need front ones anyways.
Old 09-29-2006, 09:39 AM   #10 (permalink)
CCC-norchap
so i guess will try to bolt them up this weekend
Old 09-29-2006, 09:40 AM   #11 (permalink)
Vroom?
freakinbox's Avatar
thats my game plan
Old 09-29-2006, 09:45 AM   #12 (permalink)
CCC-norchap
i read that they used the same bolts and stuff so this shouldnt be to hard.
Old 09-29-2006, 11:30 AM   #13 (permalink)
Vroom?
freakinbox's Avatar
like I said, 3 nuts on the top, 2 bolts to the... err is it called a steering nuckle? not sure on names
Old 09-30-2006, 06:34 PM   #14 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
Yes everything suspension wise from ae92 GTS will bolt up to your sr5 as well as the ae92 sedans. Right now I have a 1992 sedan with the complete suspension from a 1989 GTS sans rear sway bar. For the rear bolt up the complete assembly and use the e-brake cables and flex lines from the GTS. The front will just bolt-up aswell.
4doorGTS is offline   Reply With Quote
Old 09-30-2006, 11:46 PM   #15 (permalink)
Vroom?
freakinbox's Avatar
well to use the rear stuff from a gts best thing you could do is grab the whole subframe. From what I understand the gts and sr5 suspension on the front is the same, with exception to the sr5 and sedan not having the swaybar.
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Can someone please school me on the Corolla XRS? TitaniumSE Archived Corolla threads 3 08-03-2006 08:47 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
sr5 to gts rear disc brakes drozy88d Archived Corolla threads 6 09-28-2004 09:17 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
