Thermostat. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2006, 12:25 PM   #1 (permalink)
View tnmk's Photo Gallery
Thermostat.
I just bought the car a couple of months ago and thought it was running a little on the cool side, so I got a new stat, fails open for safety.
And now last night it was running barely above the C mark. It was fully warmed up prior to that. Could the new stat have gone bad already, or could it be the sending unit?
I'll take it apart tomorrow to see if it's failed open I guess.
tnmk is offline   Reply With Quote
Old 09-30-2006, 03:14 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Check and make sure your coolant is flowing.
Check and make sure your water pump is not leaking.
Check and make sure your radiator is not leaking.
Check and make sure your heater hoses are not crossed leading into the heater core.
Check and make sure your heater core is not leaking.
Check and make sure the butterfly (on firewall) opens and closes properly.
diver9000 is offline   Reply With Quote
Old 10-01-2006, 04:25 PM   #3 (permalink)
So how do I check to make sure the coolant is flowing? And if it wasn't, wouldn't it be over heating instead of not heating up?
Also how do I check to see if the butterfly valve is working? It must be because I do have heat and I am able to turn it off.
Hoses can't be crossed because this happened suddenly. The only thing I've done to this car on the cooling sys is change the stat and all was fine for a good 1 1/2 months or so.
No leaks that I can see or smell.
Old 10-01-2006, 04:57 PM   #4 (permalink)
diver9000's Avatar
You have 2 sending units that you should check. One is at the radiator and it basically tells the thermostat when to open and when to close.
You have one on the block that tells the water temp in the engine. I would check both of them.
You could have a bad thermostat that is stuck open and I have seen it happen, but not usually on toyotas.
Old 10-01-2006, 05:24 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
umm not sure on the year of it. BUt on my ae92 the temp sending unit is in the thermostat housing. Check that
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-01-2006, 05:46 PM   #6 (permalink)
The TN Member
View punter's Photo Gallery
What? The thermostat opens and closes buy its self, the thermo switch your thinking of controls the fan.
I would double check that you have the correct thermostat, and that it isn't jammed, if that's fine then its a temp gauge/sender problem.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-01-2006, 05:57 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
well it sounds like a temp gauge sender. Since even with the thermostat open it would eventually gain some heat.
Old 10-01-2006, 07:36 PM   #8 (permalink)
diver9000's Avatar
I agree with freak on this
Hey Punter, yes it does control the fan, but when the thermostat opens up the fan engages too to help cool it off. Without going into too much detail for tnmk I was just trying to give an easy way to look for a couple possible choices to check.. thats all
Old 10-01-2006, 07:56 PM   #9 (permalink)
Well I took out the stat to see if it was failed open and it isn't. Put it all back together, filled it back up with antifreeze, drove it and guess what! All seems to be back to normal.
So I would guess the temp sending unit is either going bad or I have a loose connection somewhere.
Thanks for all the input.
Old 10-01-2006, 07:59 PM   #10 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
could have been an air pocket in a bad spot.
Old 10-01-2006, 08:04 PM   #11 (permalink)
I suppose that would make sense, but after over a month ago that I changed the stat? Fluid wasn't low at all.
Old 10-01-2006, 11:21 PM   #12 (permalink)
Bitter's Avatar
i've seen some cars have air pockets causing some weird stuff for months on end! only overheats at idle but cools off when you rev it, hot air turns to cold when i stop, overheats at a certain rpm, temp guage goes all the way to cold during a hard stop, ect.
Old 10-03-2006, 06:44 PM   #13 (permalink)
diver9000's Avatar
Toyotas are usually pretty good about leveling out the temp and any air bubbles in the radiator most of the time. Hmmm Hope it doesnt happen again, especially with winter not too far down the road.
Gen 3 I4 Radiator Change/ Thermostat Change RningOnFumes 3rd & 4th Generation (1992–1996 & 1997–2001) 54 10-22-2011 02:35 PM
thermostat problem wilmer Pre-88 Toyota Pickup/Hilux 6 10-01-2006 05:33 PM
Thermostat stuck shut? Purdue Camry & Solara Lounge 14 05-19-2006 10:29 AM
How to check your thermostat [56k overheats] Kidane General Discussion 9 01-07-2005 07:53 PM
THERMOSTAT - Please help! OBarbas Archived Corolla threads 5 03-09-2004 11:51 AM
