which engine... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2006, 01:24 PM   #1 (permalink)
View jon_570's Photo Gallery
which engine...
when its time to change engines in my corolla i will be getting a 4AGE motor.. heres my question...i have seen many different ones..heres a list. :
1. First Generation 4A-GE (16V AE86/AE82/AE92 88-89/MR2 NA)
2.Second Generation 4A-GE (16V AE92 90-91)
3.4A-GZE (AW11 SC/ AE92SC/AE101SC)
4.4A-GE 20 Valve (AE101/AE111)
any of thses motors i get will have the ECU and everything with them..pretty much a rip out and drop in kinda thing
alright....now which motor would drop right into my 1997 toyota corolla??
jon_570 is offline   Reply With Quote
Old 09-30-2006, 01:43 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I dont think they can just drop in, you'll have wiring to do.
But they should "drop in" just fine otherwise.
Old 09-30-2006, 02:21 PM   #3 (permalink)
when i get the motor the wiring will come with the car..other than wiring for the grounds and alt and hooking up the sensors and stuff..which one will fit on the stock motor mounts??
Old 09-30-2006, 02:38 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
A series engines fit in the same mounts.
as for wiring, I have no clue.
Old 09-30-2006, 02:46 PM   #5 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
They should all fit the "A" seies motor mounts. The mounting points on all of them should be about the same. Regardess of which one you "drop" in, you need to listen to what FLASHMN was telling you. On second thought dont worry about the wiring, your right... and to answer your question each of those engines are "A" series motors so they should fit.
diver9000 is offline   Reply With Quote
Old 09-30-2006, 04:17 PM   #6 (permalink)
i want the 4AGZE motor because its already S/C and i could upgrade the pulley for more power..but ive heard i have to buy a different hood because of the intercooler...
Old 09-30-2006, 04:35 PM   #7 (permalink)
Nordschleife racer
Michel H's Avatar
View Michel H's Photo Gallery
Why not fabricate some piping yourself and locate the IC behind your front bumper ?
Much better cooling, less heatsoak.
Michel H is offline   Reply With Quote
Old 09-30-2006, 04:48 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
or fit an air to water intercooler.
I'd go with GZE because naturally aspirated is boring.
Old 09-30-2006, 05:30 PM   #9 (permalink)
diver9000's Avatar
There are a lot of options for that engine. Move this or that around or whatever you want to do in a lot of the cases. You can make your own hoodscoop with some fiberglass or use your hood and have someone do it for you. Its not hard to do either way. You just need to know the measurements for your cuts. It even easier if you have a BIG budget!
Then there is virtually no limit....
Good Luck
Old 09-30-2006, 06:15 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Or get a hood scoop from a mitsubishi pajero Turbodiesel and weld it on. Looks 1000x better than some fiberglass crap.
Old 09-30-2006, 09:20 PM   #11 (permalink)
theres a hood from a 92 toyota..cant remember what one..but if u find it as a junkyard it has a scoop that will clear the SC and flow air to it and it will fit on a 1997 corolla
Old 10-01-2006, 12:13 AM   #12 (permalink)
View CRASHDRIVE's Photo Gallery
ill pick the 4agze from a AE101 i had a 20V with mild mod and its a POS.16V all the way.
CRASHDRIVE is offline   Reply With Quote
Old 10-01-2006, 01:37 PM   #13 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
I'd recommend the 4AGZE. Torque for the win, plus you could ramp up to a 4AGTE with minimal effort. Not to mention source repair parts / manuals from the US, unlike the 20V.
WIP AE102.
Piloter is offline   Reply With Quote
Old 10-01-2006, 05:02 PM   #14 (permalink)
diver9000's Avatar
You are already having trouble finding an ECU for a gze. Call around and see if you can find parts for your gze, not that you need them yet but just call around and do a "what if" and see if they can find whatever it is you are looking for. Good Luck
Old 10-01-2006, 05:42 PM   #15 (permalink)
The TN Member
View punter's Photo Gallery
If you want to run a gze gearbox, (you should if you choose a 4agze) then you will need 3 new engine mounts.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
'98 Corolla engine noise earthmover Archived Corolla threads 5 10-28-2009 09:16 PM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 05:07 PM
