cv axle removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2006, 01:49 PM   #1 (permalink)
View knoxtoy87's Photo Gallery
cv axle removal
i'm having hard time removing the left and right cv axles. is there a special tool or an easy way to remove it? i need to change the oil seals on both sides of the trans. it's leaking.
knoxtoy87 is offline   Reply With Quote
Old 09-30-2006, 02:49 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Are you having trouble removing the cv axle from the transmission or the back of the hub?
What year/model is the car?
diver9000 is offline   Reply With Quote
Old 09-30-2006, 04:05 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
a long screwdriver and pry against the axle and trans case, it'll pop out.
Old 10-01-2006, 01:06 AM   #4 (permalink)
cv axle from trans 89 corolla. is there a oil seal?
Old 10-01-2006, 01:18 AM   #5 (permalink)
Bitter's Avatar
there should be! its probably in the trans case, just use a flatblade to pry the old seal out and then install the new seal with a seal installer.
when i did my axles my old seals looked just fine so i didnt replace them. no leaks so far!
Old 10-01-2006, 10:28 PM   #6 (permalink)
im having hard time prying the axle out. help
Old 10-01-2006, 10:48 PM   #7 (permalink)
View toyomoho's Photo Gallery
The end of the drive shaft inside the differential has a spring clip holding the shaft in. There might be a location on the inboard CV joint body where you can place the end of a pry bar. The axle will need to be pried out. It is almost like popping the axle shaft out. Don’t pull on the axle; this will most likely just result in the CV joint pulling apart.
Engine swap, axle removal problem dacecil 1st & 2nd Generation (1983–1986 & 1987-1991) 4 09-02-2006 09:47 PM
92 V6 Rhd Axle Removal Mechanic 3rd & 4th Generation (1992–1996 & 1997–2001) 8 05-14-2006 08:56 PM
Replacement CV Axle for my Gen2?? afyouthbrigade 1st & 2nd Generation (1983–1986 & 1987-1991) 1 08-17-2005 11:04 PM
passenger side cv axle bowlofturtle Camry & Solara Lounge 7 05-31-2005 05:19 AM
scraping sound after replacing cv axle foompla Camry & Solara Lounge 3 05-24-2004 04:22 PM
