ok.... sounds like this question was answered completely wrong....
first off.... mallory and MSD are NOT the same brands.....
secondly... if you're going from a 4afe to a 4age and want to use the 4afe ecu.... you need to find the right 4age distributor (and NO they are not all the same)... i've seen at least 3 different 4age dizzy's.... the one you need will have the same matching gear numbers on both the upper and lower cogs inside of the distributor..... then you need to pull the wiring out of the 4afe distributor and re-arrange the magneto pickups as to match the 4age's distributor (this is so you can figure out which wires go where).... then it's just a matter of extending the wires and adding the stock 4afe plug
