AE92 Jacking points - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2006, 11:32 PM   #1 (permalink)
View Valkyrie90AE92's Photo Gallery
AE92 AE92 Jacking points
What are the best jacking points for the car? The Haynes manual just lists the frame rails, but using them seems a bit awkward to change the rear brakes. Is there anywhere in the rear where you can safely place a jack and jackstands to raise the rear safely? I would prefer to have both rear wheels in the air, so as to get the brakes done as fast as I can.
Oh, it is a 1990 Corolla sedan.
Thanks
Valkyrie90AE92 is offline   Reply With Quote
Old 09-30-2006, 11:58 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I use the spot infront of the door/ behind the wheel well. Thats where it is on my Jetta and it seemed sturdy enough to use that spot. For the rear I put it where one of the suspension arms mounts to the body.
If you take it to a shop they will typically use the frame rails, the metal lip along the rocker, or the spots I just mentioned.
That is unless it's canadian tire and they think jacking it up under the driver side floor pan is a much cooler idea
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
Fs: Gta: 1990 Ae92 Gt-s sleepy Vehicles 35 12-09-2005 01:58 AM
left over parts from canadagts for ae92 CanadaGTS Archived Corolla threads 0 11-06-2003 09:11 PM
Major traffic infraction fines and demerit points Dredd2099 General Discussion 12 06-26-2003 10:27 PM
