1991Corolla will not start when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2006, 03:50 AM   #1 (permalink)
View Salinger's Photo Gallery
I have a 1991 corolla with 4AFE engine that doesn't want to start when cold. Dumps gasoline in the cylinders and engine seem to rotate without compression. Whenever I get it started and warmed up, car runs ok. No code in ECU. I would appreciate any help I can get.
Salinger is offline   Reply With Quote
Old 10-02-2006, 08:49 AM   #2 (permalink)
View tashirosgt's Photo Gallery
I curious what you mean when you say the engine seems to rotate without compression. And you didn't mention whether you checked for spark.
tashirosgt is offline   Reply With Quote
Old 10-04-2006, 05:51 PM   #3 (permalink)
Old 10-04-2006, 05:55 PM   #4 (permalink)
tashirosgt I checked for spark and spark is there. The engine crank as if the timing belt is stripped. Just no kind of compression on the engine. Checked timimg and it didn't jump the timing
Old 10-04-2006, 07:33 PM   #5 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
No Compression..............sounds like a blown headgasket to me..
diver9000 is offline   Reply With Quote
Old 10-05-2006, 01:04 AM   #6 (permalink)
diver9000's idea brings up the question of whether a blown head gasket always results in water mixing with the oil. I suppose not. So a compression test on a cold engine would be a good idea even if you don't have the classic symptoms.
Old 10-05-2006, 06:34 PM   #7 (permalink)
diver9000's Avatar
It is a classic symptom when the oil and water mix, but it is not always the case. You can have a small tear in the gasket and it might not leak water for awhile. It could also be your valves, but to loose all compression seems a bit extreme from out of nowhere.
When you checked the timing.. how did you check it? Even if its a tooth off, that could affect it.
Old 10-05-2006, 07:31 PM   #8 (permalink)
The TN Member
View punter's Photo Gallery
Sounds like its low on compression.
So it starts fine when warm? Is it using any oil/water?
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-06-2006, 11:13 AM   #9 (permalink)
diver9000's Avatar
Hey Punter..since everyone seems to agree with the compression idea. Where would you take the idea from here?
2.2r Cold Start Problem redntanmiata 89-95 Toyota Pickup/Hilux 3 02-21-2006 07:52 AM
Cold Start Sensor Vs. ECT Temp Sensor fourdoor Camry & Solara Lounge 2 02-20-2006 06:28 PM
94 22re cold start problems and various issues rentz 89-95 Toyota Pickup/Hilux 14 01-19-2006 05:04 PM
price on 2 gen cold start injector? spills1969 Camry & Solara Lounge 1 07-22-2003 11:32 AM
Cold Start Switch 86CRESSIDA86 General Discussion 7 01-07-2002 10:10 PM
