Pinhole in gas tank, suggestions? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2006, 11:14 PM   #1 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
Like the subject says, I have a pinhole (from what I gather) in my tank. If it is filled past half way, I get a very slow drip. Could this be anything other than a hole in the tank? I'm thinking not since it doesn't leak any other time than when its filled past half way, all lines are new and it doesn't leak at all when running. My other question is, does any one have expierience with JB Weld? I've had a couple mechanic friends recommend this stuff, I went out and bought some, but am unsure if it will do what it says. Any help, greatly appriciated.
Kr0n1k is offline   Reply With Quote
Old 10-03-2006, 02:16 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
might wanna check the filler tubes and the gasket at the sender/pump hole (under back seat) it might not be the gas tank at all!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-03-2006, 11:12 AM   #3 (permalink)
View silkydraws's Photo Gallery
As far as cold welding Belzona is best. Get it at industrial supply stores or maybe body shops could point it out. Like the old Red-Hand epoxy but much better. Really tho even Wal-Mart has some better 2 parters better than J-B Weld. Not that I'm putting down the old JB but there are much better now.
silkydraws is offline   Reply With Quote
Old 10-03-2006, 11:43 PM   #4 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
The gasket could actually be the culprit, since my tank certainly doesn't look rusty at all, I've been under that part of the car numerous times. I hate taking out the back seat, grr... and thanks for the suggestions on the cold welders silky, though I'll probably use good ole JB since I already bought the stuff (if it comes down to it actually having a hole in it). Now that I think about, would a bad gasket leak when the car is on an incline also? When I backed it up onto the ramps to put the exhaust on it had a pretty good drip goin. Damn this car, its so hard to modify when all you do is maitnence every time. This and the speedo not working have been irritating me for a while now, and between getting pulled over for going to slow (yea, I know, gotta love bored cops, 30 in a 35, I was close) and almost having the car towed because people could smell gas (even though it wasn't dripping or anything) at my apartment complex, its time to get on the ball.
Old 10-04-2006, 12:05 AM   #5 (permalink)
View toyomoho's Photo Gallery
Have had this problem before, a gasket or hose on the tank. Also check the seam where the two parts of the tank are welded together.
Old 10-04-2006, 12:29 AM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
they make special gas tank sealant epoxy. i'd suggest that stuff.
Old 10-04-2006, 10:13 AM   #7 (permalink)
20V 10000rpm
View chotto's Photo Gallery
there is gas tank putty that you can get at the parts store
just apply that to your pinhole size hole and it will seal itcould also be the filler neck hose clamp might be loose
MX73 Twin Charger Drift Machine
chotto is offline   Reply With Quote
Old 10-04-2006, 06:54 PM   #8 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
Whoa, lots of people with leaky gas tanks? Thanks for all the help, I'm gonna have a look tomorrow finally, now that I have a day off, so maybe I can park it at home again. The seams look good, and what would the epoxy do? Same thing as the JB?
Old 10-08-2006, 11:32 AM   #9 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
The other epoxy is designed for gasoline and to not break down if gas gets on it. JB weld once dry should be good as long as it will adhere to the tank. I dont know how the JB weld will hold up if gasoline gets on it. It may not harden properly. But like you said, you've already bought it so you may as well try it. Good Luck.
diver9000 is offline   Reply With Quote
03 Corolla S guzzling too much gas GaviN 9th Generation (2003-2008) 11 03-04-2008 08:13 PM
Excessive pressure in gas tank? speedyts49 Celica Forum 6 08-28-2005 07:45 PM
Gas/Fuel tank Leaking?? Troyfrezze Camry & Solara Lounge 3 02-15-2005 08:27 PM
Charcoal canister repeatedly filled with gas Lokamaya Camry & Solara Lounge 18 01-03-2005 07:04 PM
replacing gas tank in a '92 sally Archived Corolla threads 5 11-20-2004 04:29 PM
