How To Remove AE86 Sunroof? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2003, 02:23 AM   #1 (permalink)
86B
View 86B's Photo Gallery
I have this parts car and i do want to take out the sunroof, but i have no idea how to do it without turning on the car... anyone know how to do it without turning on the car?
BTW the ignition starter for the car is busted so i don't know other way to start the car... i also don't know how to hot wire the car...
2003 IS300
1997 ES300 (Sold)
1986 Corolla GTS Hatch (Sold)
1985 Corolla GTS Hatch (Sold)
1987 Corolla SR5 Hatch (Sold)
86B is offline   Reply With Quote
Old 04-27-2003, 06:06 PM   #2 (permalink)
since 1996
Voodoo.Priest's Avatar
View Voodoo.Priest's Photo Gallery
Do you plan on stripping the whole car?
I can't tell you right now because I don't have enough time to type it all out. I'll post it when I came back home.
But I will warn you this is a pain in the *** to get out.
1997 Corolla SD sold __________________ 1986 Corolla GT-S liftback *Christine* R.I.P.
1986 Corolla GT-S liftback *Ashley*_____ 1986 Corolla GT-S coupe *Martha* R.I.P
2005 Impreza RS 2.5
Voodoo.Priest is offline   Reply With Quote
Old 04-27-2003, 07:36 PM   #3 (permalink)
86B
Since i have decided to go with a newer car and forget about my project86... i wanted to strip my parts car of everything and see what is still useful and sell it out to ppl that need them...
Time consuming?... don't worry i'm finished exams on tuesday and it's holiday for me!!
Thanks for your help Voodoo Priest
2003 IS300
1997 ES300 (Sold)
Old 04-27-2003, 07:56 PM   #4 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
to take out the sunroof u just have to put a phone book on top of it and then drop something reallllllly fuckin heavy on the phone book
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 04-27-2003, 09:30 PM   #5 (permalink)
since 1996
Every thing here that I'll be typing is right out of the official Toyota repair manual. I my self didn't follow some of these steps because I had already stripped all the interior as well as many other parts by this point. Though I may have inadvertently folowed them. :o
Removal of sun roof:
1. Disconnect battery cable from battery.
2. Remove center cover of control box.
3. Remove control switch.
4. Remove motor through service hole.
5. Remove wind deflector.
6. Remove guide rail cover
7. Remove sliding roof and guide rail.
(a) Apply adhesive tape to protect the body.
(b) Pull the sliding roof with the guide rail upward to remove.
Dissasemboly of sun roof:
1. Remove sliding roof headlining.
(a) Pry off the clip.
(b) Pull the sliding roof headlining rearward to remove.
2. Remove guide rail and cable guide casing.
(a) Loosen the screw.
(b) Pull the guide rail rearward to remove.
(c) Pull the cable guide cassing to remove.
3. Note the number of shims on the front and back.
4. Remove the front shoe.
5. Remove drive cable and rear shoe.
6. Remove drive cable from cable casing.
Removal of sliding roof panel:
1. To remove only slyding roof panel.
(a) Pull loose the clips and slide the headlining rearward.
(b) Remove the front and rear shoe bolts.
(c) Remove the roof panel.
2005 Impreza RS 2.5
Old 04-27-2003, 10:33 PM   #6 (permalink)
86B
Thanks for your write up!!
2003 IS300
1997 ES300 (Sold)
