20v swap help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2006, 11:36 AM   #1 (permalink)
20v 4dr AE92
View Corolla101's Photo Gallery
20v swap help!
Hey guys
I have a AE92 with the 4-af in it:
http://s92.photobucket.com/albums/l9...&addtype=local
and im wondering what i need for the swap, i've read the old posts but nothing that clarifies what i need exactly for the 4-af.
I believe im going to need the fuel pump and maybe the fuel lines??
Will the CV shafts work from this engine for the 20v?
should i replace the motor mounts?
I also have a automatic 4-af atm and the 20v comes with full wiring, engine, and manual transmission, so im going to need a clutch master cylinder? and a clutch pedal?
any help is appreciated~!
Corolla101 is offline   Reply With Quote
Old 10-04-2006, 12:53 PM   #2 (permalink)
Nordschleife racer
Michel H's Avatar
View Michel H's Photo Gallery
You don't need fuel pump/lines. CV joints etc. are fine too. I recommend replacing the mounts though, I didn't and regret it Radiator is fine too.
I have no idea about the whole clutch/pedal thingy though but I guess you'll need it since you're going from auto. -> manual.
Michel H is offline   Reply With Quote
Old 10-04-2006, 12:59 PM   #3 (permalink)
20v 4dr AE92
alright thanks for ur help man
one question tho, the 4-af fuel pump is mechanical so
Old 10-04-2006, 03:14 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
Yes you will need an EFI pump, the best way (IMO) is to swap your tank for one from an efi corolla, then run a new fuel line to the engine, you can use you existing fuel line as the return.
Yes you can use you auto axels on the 20v gearbox. (you WILL get torque steer though)
Yep just get the clutch master, slave, clutch pedal and brake pedal from a manual ae92.
And yes motor mounts is probably a good idea, to save cost I only replace the front and rear, as these are the ones that fail first.
Don't forget to do the cambelt, waterpump and thermostat on the new engine.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-04-2006, 03:29 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Originally Posted by Corolla101
Hey guys
you need the tank and fuel lines.
it's usually suggested when doing a motor swap, always easier to change them when the motor is out.
Not sure if the ae92 clutch pedal is part of an assembly, if it is you will need the assembly. But you will need the master cylinder for sure. You will need the linkages and depending on what tranny it has you might have to modify the piece that holds the shifter, for the 6 speed.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-04-2006, 04:17 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
or you make a swirl pot into the engine bay and use the carb fuel pump to pump fuel to the swirl pot from the fuel tank, and you have a high pressure pump feeding from the swirl pot.
Old 10-04-2006, 04:29 PM   #7 (permalink)
20v 4dr AE92
thanks alot for your help guys
as far as the clutch cylinder, what car would this come out of?
because i work at partsource and if i know the vehicle appliation i can look it up
thanks again
Old 10-04-2006, 04:44 PM   #8 (permalink)
The TN Member
Any FWD 4age powered car, although I'm 90% sure 4afe's are the same.
Old 10-04-2006, 07:09 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
yea I am also pretty sure the masters are the same, thought the slaves were different.
Old 10-04-2006, 10:03 PM   #10 (permalink)
20v 4dr AE92
do i have to use a whole tank and fuel line? because im kinda short on funds atm.. can i just put a fuel pump somewhere inline and when i have the money down the road do the whole thing?
Old 10-04-2006, 10:58 PM   #11 (permalink)
The TN Member
You will need EFI line as the pipe and fittings are different, EFI is much higher pressure.
You could just put an efi pump inline and run new lines.
I would have thought a tank and efi lines would be quite cheap though. (second hand of course)
Old 10-04-2006, 11:17 PM   #12 (permalink)
20v 4dr AE92
ya im just gonna pull it out of the wrecker, my work wants $352 for a new 1
thanks for the help guys, ill keep u updated and take some pics of the engine when it gets in
Old 10-05-2006, 01:48 PM   #13 (permalink)
20v 4dr AE92
engine just came in!!
Old 10-05-2006, 01:53 PM   #14 (permalink)
Vroom?
freakinbox's Avatar
well you should use the tank since the carb tank doesn't have baffles to stop the fuel from sloshing around and with efi that will cause a problem since if you corner hard it will end up not getting fuel.
With the lines, again yes as the carb lines are meant for lower pressure, and I think there is no return line. For those you can buy the lines new and bend them how you need them. Not sure with toyota but alot of dealers no longer sell prebent lines anyways.
Old 10-05-2006, 01:55 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
No you dont have to get a new fuel tank, you do this http://www.sdsefi.com/techsurge.htm
Yes theres a returnline, yes the HOSES are meant for lower pressure, the fuel hard-lines are made of steel and will hold efi system pressure.
4age 20v vs b18 swap good_old_geo Archived Corolla threads 15 08-28-2006 07:37 PM
20V Swap, can someone help? -HiTMaN- Archived Corolla threads 8 02-24-2006 05:02 PM
20v ITBS to 16v, or 20v Swap canadianae92 Archived Corolla threads 32 12-30-2005 09:25 AM
20v 4AGE swap into AE86 Hachi Driven Archived Corolla threads 4 11-08-2005 08:05 PM
20v jdm swap djprefix Archived Corolla threads 6 11-17-2003 02:13 PM
