95 corolla brake problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2006, 03:10 PM   #1 (permalink)
View wayfast's Photo Gallery
ok i hope someone here can help me, recently the brakes on my 95 corolla started going down to the floor, they still slow the car down, but once it's stopped, the car will inch forward unless you pump them.
brake fluid is full, what would you guys this the problem is?
wayfast is offline   Reply With Quote
Old 10-05-2006, 03:57 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
have you taken a look at the pad thickness?
diver9000 is offline   Reply With Quote
Old 10-05-2006, 05:54 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
check for fluid leaks.
Old 10-05-2006, 06:00 PM   #4 (permalink)
diver9000's Avatar
It sounds like the brakes are mushy, due to the need for a brake job. I thought about air in the lines but he said the fluid is still full as if the brakes have never been touched, or at least not in a longgggg time.
Old 10-05-2006, 06:15 PM   #5 (permalink)
actually the brakes were just done maybe a month ago
Old 10-05-2006, 06:20 PM   #6 (permalink)
diver9000's Avatar
sounds like you just found an air pocket that somehow managed to avoid being bled out or you have a leak/loose connection somewhere. It could be a bad master cylinder but I would check the easy stuff first. Try bleeding your brakes and look for signs of leakage. Make sure the bleeder valves on top of the calipers are tight. They are easy to break off so be careful not to over-tighten.
Mysterious Brake Problem (2000 Camry) stangjason 3rd & 4th Generation (1992–1996 & 1997–2001) 7 07-27-2006 10:47 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
Corolla brake question White Buffalo Archived Corolla threads 8 06-26-2006 08:55 PM
95 corolla brake lights TRDwasiq Archived Corolla threads 2 06-05-2006 06:48 AM
1998-2001 corolla brake swap question trdcorolla Archived Corolla threads 2 03-12-2005 04:49 PM
