93 corolla charging problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2006, 08:48 AM   #1 (permalink)
View srswarts3's Photo Gallery
i have a 93 corolla 1.6 automatic with a weird charging problem
the car had a blown alternator fuse, so we replaced the fusebox with a proper working fuse, the battery still wont charge. the car has a new battery and we have tried 3 different alternators in this car, they all have the same results. i put a multimeter between the + bolt on the alternator and a common ground, it read .7 volts so obviously the alternator is not charging enough...is it possible we got three bad alternators? is the car popping alternators? the car runs like a champ when connected to another car via jumper cables. completly stumped dont know what to do with this car.
helppp
srswarts3 is offline   Reply With Quote
Old 10-06-2006, 10:16 AM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Put the multimeter on the battery posts and see what its reading. Disconnect the battery while the car is running and see if the car continues to run. With the battery disconnected from the alternator get a reading on it. If you still have bad readings I would check the cable that runs from the alternator to the battery. You may have to unwrap the looming/tape around your harness, but thats ok, you can always retape it. I would check the engine ground as well.
diver9000 is offline   Reply With Quote
Old 10-06-2006, 01:08 PM   #3 (permalink)
ahh sorry forgot to mention i did infact test the alternator's output with the cable disconnected and the car running off another cars charging system, the alternator puts out .7ish volts at idle and maybe a maximum of 4v when revved
ive been told it may be the voltage regulator....makes sense....does anyone know where they are located on this rolla? not inside the alternator i'm assuming
out of curiosity what do the three wires on the oval plug going to the alternator do?
Old 10-06-2006, 07:45 PM   #4 (permalink)
diver9000's Avatar
How do you test the alternator's output by running off another cars charging system? I dont understand what you did?
All I meant was to do this: If the car will crank, then crank it up, pull the battery cables off of the battery. Check the output voltage of your alternator while your car is running off of your own alternators power. While you have your car running on its own power turn on the headlights and see what the voltage is then. Oh yeah..... This may sound stupid but what range on your meter are you using to check the voltage? If its to low or to high, you know that can change your reading....
Good Luck
Old 10-06-2006, 09:40 PM   #5 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
Check ground wires.
Check power wire to alternator
Check voltage regulator for Alternator
Make sure your battery posts are clean
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 10-06-2006, 11:16 PM   #6 (permalink)
the car dies as soon as you remove the positive battery terminal because the alternator is putting out almost nothing
where is the voltage regulator located and how do i test it??
Old 10-06-2006, 11:54 PM   #7 (permalink)
diver9000's Avatar
Far as I know its in the alternator. Sounds like somebody is giving you bogus alternators or maybe one for a different year than what you asked for.
Old 10-06-2006, 11:55 PM   #8 (permalink)
diver9000's Avatar
Now I would check the wire from the alternator to the ECU too.
Old 10-08-2006, 11:09 AM   #9 (permalink)
any idea where i can find a shopmanual for this car online?
Old 10-08-2006, 11:12 AM   #10 (permalink)
diver9000's Avatar
Check www.club4ag.com technical specs section. Dont get all into the chat section. Just go to the tech section and see if you can find anything. I'm sure someone out there has one somewhere.
Strange Stalling Problem on 93 Camry 4cyl - Please Advise MSgtVac 3rd & 4th Generation (1992–1996 & 1997–2001) 35 11-02-2008 01:26 PM
90 4runner charging problem sroot1 4Runner Lounge 2 10-20-2006 03:38 AM
Not sure what year, 93-96 corolla radio/center console lighting problem (Pics) SubaruWRXMike Archived Corolla threads 10 10-20-2004 05:53 PM
my 93 corolla needs some umph td420 Archived Corolla threads 1 10-18-2004 11:39 AM
