Parking lights won't turn off.
My brother just picked up a 95 Corolla and last night when he came home the parking lights wouldn't turn off. I've played with the light switch, ignition, shifter, and brakes. Nothing will turn them off aside from disconecting the battery or pulling the fuse. The switch still works fine to turn the headlights off and on, as well as the turn signals and high beams.
Right now I'm thinkiing it might be a burnt out relay. Is this a common problem with these cars? It's a 1.6L manual trans, four door. If that helps any?
Thanks a lot for any insight you can give me.
