Ever expanding project - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2006, 09:53 PM   #1 (permalink)
View poorboychevelle's Photo Gallery
Hi, Im kinda new to the toyota scene, mostly been researching so far. Heres the plan
20 V Black top head, on a 7A block with the 7A crank. I know a Porcshe 944 timing belt can be used to mate a 7A with a GE head, but what about the 20 Valve. I was wondering if there were any recommendations on con rods, since im planning on running 4agze pistons. The intake manifold would be a custom application, since im planning on runing a turbo (hence the Z pistons) The I also want to run the 6 speed. All of this would be shoveled into a 94 corolla. Are there any major conflicts anyone can foresee? (Ive been told the 4agze pistons will still clear the 20 valve heads) I know it'll be a pain to get a computer to run it, but hey thats the fun.
This morning I woke up and my plan took another turn...... I realized that the earlier generation corolla was offered in all wheel drive, with a 5 speed and a A block. Anyone know details on the durability of the AWD drivetrain? Would it be a worthwhile investment? Thanks guys.
poorboychevelle is offline   Reply With Quote
Old 10-08-2006, 10:41 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
connecting rods you ask, I say go 4agze/silvertop ones since they share them. Since if I recall right it's the bore thats different, not the stroke
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-09-2006, 12:07 AM   #3 (permalink)
The TN Member
View punter's Photo Gallery
7A block? You need 7A rods, 4A rods are too short.
Either get the standard rods shot pened or get some custom ones made.
The standard rods are reasonably strong
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-09-2006, 12:21 AM   #4 (permalink)
The TN Member
This info is for a 16V head conversion only(bluetop) (i havent done a 20V so wont risk commenting on them)
Cambelt to use is from a Porshe 944 turbo Gates part number is T107.
you have to run adjustable cam gears to get the cam timing right.
the compression on this setup 7age is apporxiamately 8.1-1
gudgeon pins= if your going to run 4age pistons on the 7afe rods we found the easiest way to do this was to use the 7afe pins but put them in the lathe and skinny them up with a piece of emery cloth, pretty seat of the pants but worked fine. (you will see why we did this if you every actually get round to doing this conversion)
If you want to make an N/A one and intend putting the 4age pistons in remember that the compression will be higher than what the same pistons would be in a 4age. basically redtop pistons in a 7age situation willresult in something like 12.5 to 1 compression with a .8mm gasket.
Old 10-09-2006, 12:26 AM   #5 (permalink)
The TN Member
For a 20v 7age (I've got no experence in these just quoting off the web) a standard 16v cam belt can be used.
This setup is running a bluetop cambelt.
Ross racing dished forged pistons 8.0:1
Saenz H-Beam Billet steel alloy custom rods
7afe block modified to suit the rods
7afe crank, balanced and dowels for the flywheel
7afe flywheel modified to fit Quartermaster twin plate clutch
7afe standard alloy sump
20v blacktop head
This engine has 330kw @ the wheels on 27psi
Old 10-09-2006, 12:32 AM   #6 (permalink)
where on the web did you find that info punter? sounds interesting....
Old 10-09-2006, 12:59 AM   #7 (permalink)
The TN Member
http://toyspeed.blakjak.net/profiles/profile.php?id=172
Thats the 7agte above. Its a crazy car.
Michael T’s Artic Frost Project: 1st Gen 2 Reverse Trunk Lid michaels_artic_ Solara 4 04-30-2007 06:41 PM
Finished my audio project nicoj122 Audio, Video, and Security - Tech 4 03-18-2005 08:41 AM
"SideFX" Project RCNICA Archived Corolla threads 2 01-20-2005 10:58 PM
Project Code Name: OMFG 2advanced Archived Corolla threads 20 11-18-2003 12:47 AM
Bitching about Ultimate Racing re 5SFTE project SpectraBlueCam General Discussion 17 06-09-2003 04:38 PM
