4af headgasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2006, 11:42 AM   #1 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
4af headgasket
Just wondering on the aprox. cost, torque spec on the head bolts. And what else I HAVE to replace at the same time if I do it.
I assume whats what it is since I am losing oil like mad, looks like from the front of the block. The head is clean and my antifreeze is down.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-09-2006, 12:56 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
headgasket is probably around 20bucks. As for bolts, dunno never replaced them, they arent stretching bolts.
Tightening sequence, from center outward, in three steps:
1: 20Nm
2: 40Nm
3. 60Nm
Old 10-09-2006, 12:59 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
Don't need to replace anything else? 20??? from where! lol
Old 10-09-2006, 01:08 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
somewhere else than the dealership
Old 10-09-2006, 02:20 PM   #5 (permalink)
In love with boost
emiliorescigno's Avatar
View emiliorescigno's Photo Gallery
Welcome to the BHG (blown head gasket) world of pain!!!!! Both of my 4A-FE powered rollas bit the dust because of BHGs, and now I have a MKIII Supra, and we know how that goes....
emiliorescigno is offline   Reply With Quote
Old 10-09-2006, 02:25 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
well I checked the oil cap and no white crap. But it's in the anti freze. It happened to my 90 jetta. Where instead of the anti freze getting into the oil the oil got into the antifreze, which I didn't think would happen with the 4af.
Old 10-09-2006, 03:43 PM   #7 (permalink)
The TN Member
View punter's Photo Gallery
What else do you need to replace?
You'd need to find out why it blew and fix that. And check the head is still square.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-09-2006, 03:48 PM   #8 (permalink)
View 94_Rolla_Guy's Photo Gallery
just the head gasket and the head bolts NEED to be changed, things you can change are valve stem seals (since the heads off) water pump, timing belt, cam seal, crank seal, valve cover gasket.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-09-2006, 03:53 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Wrong, the bolts dont need to be replaced, because they arent torque to yield bolts, they dont stretch. Just keep them in the right order and you'll be fine.
Old 10-09-2006, 04:26 PM   #10 (permalink)
Vroom?
freakinbox's Avatar
yea I would love to change all that but since I am broke the money for the headgasket will be trouble enough :p
I think the issue is with cylinders 1 and 2.
here's some pics
Sparkplug 1
Sparkplug 2
Sparkplug 3
Sparkplug 4
Where the oil is
This is the waterpump right? Looks like oil on it too
Lastly.... here is the Rad. The oil fill cap and dipstick look clean of the white stuff as I said. Rad wasn't so lucky
And lastly on engine stuff, looks like I have a fuel leak at the pump
Old 10-09-2006, 05:04 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Plugs look ok, besides looking at plugs doesnt tell you anything.
Old 10-09-2006, 05:23 PM   #12 (permalink)
Gameroom cash: $134355
unless toyota put them on the 4ag's and not the 4afe's.... they are stretch bolts.... there have been many ae86 & mr2 owners to snap the bolts..... i personally haven't bought new bolts.... i buy new engines
i wouldn't reccommend a $20 head gasket.... it could be a lot of work for someone who isn't used to getting deep into cars.... go with a toyota gasket or an aftermarket (of your choice) 4age gasket... (yes they are the same)... if you want a thinner toyota gasket, get one for a 7afe
Old 10-09-2006, 05:30 PM   #13 (permalink)
Vroom?
freakinbox's Avatar
yea I figured the 4age and 4af head gaskets would be interchangable since it still has to go through the same passages in the block.
Suposidly my dad says the red on the #1 and 2 plugs is from the anti freze. The other pics are mostly from around the front of the block just under the head. Makes sense to me since the other 2 don't have it.
Old 10-09-2006, 05:37 PM   #14 (permalink)
well.... obviously you don't seem really concerned about this... so i'm gonna assume it still runs...
if you do have a break in the gasket from the combustion chamber to the coolant.... generally you will have a lot of white smoke while running..... this is what happened to me on my old 4afe in the ae92 (before i swapped it)... but it would only smoke every-so often....
a simple test at most shops can be done to see if exhaust gasses are entering the coolant....
but if you have oil in the coolant... i would think that there's no breaks in the combustion chamber (unless the HG went in multiple places)
Old 10-09-2006, 05:39 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
Not when you get an OEM gasket for 20bucks.
Correct, you know what the tattletale sign of that is? 4A-GE has the 2nd and 3rd phase of the tightening process in degrees, not in NM. Thats a general key for determining if you have TTY bolts or regular non stretch bolts (applies most of the time, not 100% though)
Anyhow I gotta get some sleep, I got a class to teach in the morning.
headgasket? help needed! trd_terc Tercel, Paseo, Starlet, and Sera Forum 2 01-04-2006 11:38 PM
Vacuum on 4AF Carb Fang50 Archived Corolla threads 4 07-03-2005 01:51 AM
Fixed the choking, blew my headgasket jonrhaider MR2 Forum 2 04-26-2005 12:12 PM
4AF Parts to a 7AF |PuNiSh3R| Archived Corolla threads 3 03-05-2004 05:39 PM
G head on 4AF block? Punisher Archived Corolla threads 23 03-03-2004 10:07 AM
