4age 16 or 20 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2006, 07:13 PM   #1 (permalink)
View TRDwasiq's Photo Gallery
4age 16 or 20
4age 16v is 450$ and 20v is 800$ only the engine
so whtz up i wana knw how much hrs power 16v has
TRDwasiq is offline   Reply With Quote
Old 10-09-2006, 07:22 PM   #2 (permalink)
View kevlar corolla's Photo Gallery
Depends which 16v it is,they range from 113hp to about 130hp for na and 145 hp for the supercharged gze.The early 20v are rated at 145hp and the later blacktops are rated at 165hp.Keep in mind the 20v rated power is obtained with jdm ecus tuned for the 100 octane fuel there.It's common knowledge they are over rated for power,rev great and sound awesome but the gze will outrun a 20v and respond much better to mods.Add a pulley to a gze and a couple supporting mods and your sneaking up quick on 200hp,you'll need a few thousand invested into a 20v na to get near the peak power but you'll still lose out on mid range power to the gze.
I've supercharged a 20v using gze pistons and the gze's charger,its not running perfectly yet but it works pretty nice.Throttle response is crazy and will rev to 8k no problem(I expect that I could run it to 8500 once all the standalone tuning is done),the horrid intake set-up on the gze falls on its face before 7k.
kevlar corolla is offline   Reply With Quote
Old 10-09-2006, 07:30 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
What do you want to know?
A basic guide to power is
bigport = ~115hp
smallport = ~130hp
Silvertop = ~140hp
Blacktop = ~145hp
Thats probably pretty close to the actually power these engines make.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-10-2006, 01:56 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
$800 for the engine alone??? You can get Silvertops in the Toronto area for about $300-400 CDN, do the conversion and yeah.. $800 is basically a ripoff. Find another place that will sell them for cheaper dude.
By the way, 100 octane in Japan = 91 octane in North america.. different Octane ratings dude.
Old 10-10-2006, 06:58 AM   #5 (permalink)
View micro214_kp61's Photo Gallery
bigport = ~115hp
smallport = ~130hp
Silvertop = ~140hp
Blacktop = ~145hp
isn't it supposed to be:
bigport = ~115hp
smallport = ~130hp
Silvertop = ~160hp
Blacktop = ~165hp
since the ratings you gave the bigport and smallport are flywheel hp?
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 10-10-2006, 02:24 PM   #6 (permalink)
i was thinkin of doin swap (for my 1995 corolla u all tell me whtz up?
Old 10-10-2006, 02:51 PM   #7 (permalink)
The TN Member
bigport = ~115hp
smallport = ~130hp
Silvertop = ~160hp
Blacktop = ~165hp
Yea but from the dyno plots I've seen (after a dyno day) those numbers seem to be about right. Just my experence.
But to be honest your kidding yourself if you think a standard silvertop will ever make 160hp. Same goes for blacktops.
Old 10-10-2006, 03:53 PM   #8 (permalink)
View CRASHDRIVE's Photo Gallery
what are you going to use it for daily car + time attack or daily only or track only.
ok if you just want a daily ill go with a 20V silver top maybe open up the ITBs for better flow and mix. not bad for track use.problem you got no lowend trq
fully track ill go with a 4AGZE from an AE101 a little bolt ons and you got a good motor to race. you got low to mid trq
CRASHDRIVE is offline   Reply With Quote
Old 10-11-2006, 03:07 PM   #9 (permalink)
i don't what kinda of dyno they use but the bigport makes around 90 whp and smallport barely makes 100 whp, and that's STOCK. the standard STOCK 20V ST is around 125 whp and blacktop goes to 135 whp. again, different dynos show different graphs.
if you want to daily drive go with a stock ST, not a MAP converted like suggested above coz it'll coz you almost the same amount when swapping a BT. you'll need either a BT ECU (w/ MAP sensor) + piggyback system + proper tuning cost or a full standalone ECU + proper tuning cost = NOT CHEAP.
i call BS. i've tested both 20V MAP with open ITBs and a stock one and the response is almost the same. the sound is better but in reality it's not. we actually found out that the AFM equipped is more efficient that's why a buddy of mine went back with a stock set-up. and that's why i sold my MAP conversion kit. not worth it for me.
Old 10-11-2006, 04:59 PM   #10 (permalink)
Gameroom cash: $134355
my stock smallport (with exhaust work, 4afe ecu/map based, and failing MSD ignition and a broken dizzy cap the next day) dyno'd 109.6whp at a place that around that time was dyno'ing like 2-3% lower than the surrounding dyno's....
a friend of mine dyno'd his mr2 (late 89) with 100% STOCK engine on a mustang dyno (where other aw11's were barely breaking 100whp... even the stock gze dyno'd like 120 something at the wheels) ran 106whp
a silvertop on all stock electronics in an aw11 (at the same place i had mine done) dyno'd 120whp
that was my smallport in the ae92 running on a crappy electronics setup (modified 4afe ecu using stock smallport injectors and a bad o2)
Old 10-11-2006, 05:19 PM   #11 (permalink)
The TN Member
Yup thats what it boils down to.
I just had to point out that 20Vs don't make 160hp.
Old 10-11-2006, 10:42 PM   #12 (permalink)
i totally agree!!!
Old 10-12-2006, 08:28 PM   #13 (permalink)
i want drive it daily (problem is i find a car to race everyday so i am gona be racing alot)
i am running 4afe with obx headers custom CIA ,3'' exhaust with obx high flow cat and apexi muffler i welded it. i also hv a universal fuel pressure reg.(only bad thing is (3sp)
but i pull civics and 240s though. just wana knw if i would be able to pull Gsr or not after my 20v swap i can get the whole engine for 850$ now with everything just wana knw if i need to change motor mounts or its a direct swap ( some guy was selling me the front clip with 20v jdm for 1200$)
let me knw wht u all thing
thx
Old 10-12-2006, 09:43 PM   #14 (permalink)
View nova-rolla's Photo Gallery
does this only come in efi or carbed?
nova-rolla is offline   Reply With Quote
Old 10-13-2006, 03:17 PM   #15 (permalink)
STOCK 16V 4A-GE and 20V 4A-GE = EFI
4AGE and 4AGE 20 valves for sale.. nixem311 Car Parts for Sale 11 08-26-2010 05:07 PM
Supercharging 20 Valve 4age 20ValveMR2 MR2 Forum 19 10-10-2006 09:08 AM
parts needed 20 valve...4age TeamTRJ Archived Corolla threads 14 12-08-2004 07:21 AM
