Sure was fun changing my oil today... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2006, 12:29 AM   #1 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
Well, when I started doing the oil change it was going great. Draiplug on the Corolla's engine is right out in front so it's easy to reach. I let the oil drain for about 15 minutes then I went to tackle the oil filter, and this is where the fun started. Since the filter hangs in a direction different than I'm used to, I ended up turning it the wrong way. I massively overtightened it. I said a few words then got out from underneath the car to see if I could find a filter cap. No dice, none to be found. I remembered that a long while ago I bought a strap-type filter remover at a yard sale. I looked for that for about 15 minutes. Couldn't find it. I came to the realization that I was going to have to spear the filter to get it off. I hate doing that soooooo much!
Again, since the filter hangs in a direction than I'm used to, and since I'm lefthanded, I couldn't swing a hammer properly to hit the screwdriver, so I had to take a big ratchet and pound it straight up against the screwdriver handle. Oil started leaking out of the hole I punched in the filter which made the job of trying to get it completely through the filter that much more difficult. I got the screwdriver through both sides of the filter and turned it with all my might. At this point, I was frustrated and not thinkig clearly. I realized that again I was turning the filter the wrong way, so now it was on even tighter than before. After examining the filter from every angle I figured out which way I had to turn it. I jammed the screwdriver back through the filter and turned it the proper way. It was really damn hard to move it but it did move. I ran out of room to turn the screwdriver so I had to pull it out then punch another hole in the filter. It was harder to do it this time because the handle of the screwdriver and my ratchet were covered in oil. More words were said, and it took me a few minutes to punch through the filter. I finally got the old filter off!!!
Now I went to look for the spare filter I had somewhere. Somewhere was right, I forgot where I had put it. I finally found it then attempted to put it on the car. Hmm, what the hell, why isn't it going on? I swore a bunch and got even more frustrated. I tried and tried and tried and just could not get the damn thing on. I thought the baseplate of this spare filter looked the same as the other one. I tried again, still wouldn't go on. I looked at the baseplates of the old filter and the spare one and to my horror realized that they weren't the same at all. The spare filter had a different thread and was a bit wider than the old filter. I 'praised' the Almighty One again then took a deep breath.
My stepfather has an old 88 Celica sitting in back of the yard and I realized that I could use the oil filter off of it on my Corolla. The filter I put on it (he doesn't do oilchanges, or any other maintenance) was a Maxlife filter. It wouldn't have more than 2000 miles on it. The filter on the Celica is easier to get to, but there's even less room to get your hands in there to turn it. At this point I feel like hitting my head against a wall. Remember earlier how I said I couldn't find a filter cap or strap wrench? Well this was even more of a hindrance now. I did more cursing. I had to go next door and see if my neighbour had anything I could use. All he had was a rubber band type strap wrench. Well that's just great, I didn't know how to use the thing. I tried using it and it didn't work. It took me 20 minutes I figure until I figured out how to use it, and off came the Maxlife filter. The filter was completely empty of oil by the way.
I finally get an oil filter on the Corolla, then just to top off my adventure, I start the engine to move the car off the ramps and forgot to put the oil cap back on! That wasn't too funny to see oil spurting out of the filler hole. I just had to laugh at that part, after everything I'd been through in the past 2 hours then that happened. I took the last bit of degreaser and just covered the fender and engine with it. I grabbed the biggest bucket I could find and turned on the outside water tap and filled it. I did that 4 times and figured that's all the oil that's going to come off. I took the car up the road a little way to dry off the engine a bit. I get back, clean up the yard a little and put stuff away. Then, I came in the house and started typing this! It took me about 2 and a half hours to change the oil on my car. The worst oil change I've ever done.
Infinitrium is offline   Reply With Quote
Old 10-10-2006, 01:03 AM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Guess the question is are you a girl or a guy....And if your a girl are you blond?
Seriously....I've had a few unforgettable days like that myself and feel for you, hope their far and few between
~Radd
Raddman is offline   Reply With Quote
Old 10-10-2006, 01:39 AM   #3 (permalink)
View toyomoho's Photo Gallery
More then one person has attempted to remove the filter by turning it the wrong way, installed it too tight requiring the screw driver method or left the oil cap off! Righty tighty, lefty loosy. One time installed a new filter and snugged it down. Then started the engine to check for leaks, oil was going everywhere. Removing the filter, found the threads were defective and did not allow the filter to seat properly. Fortunately still had the old filter to reinstall. Your next oil change should be a lot easier and less of a mess.
Old 10-10-2006, 01:40 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
What car was this for?? I know the AE92 filters are a pain in the ass to do, specially when the car is still HOT!
Old 10-10-2006, 08:16 AM   #5 (permalink)
This was on my 88 Corolla wagon. I can put my hand on the filter from underneath the hood but I can't get a real good grip on it. Heck, if I wasn't such a tub of lard I could do the entire oil change without putting the car up on ramps.
Old 10-10-2006, 12:22 PM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
that filter isnt THAT hard to get to, just put something on your arm and a glove then reach down next to the header and get er done. i go from the top with my left hand, its a little harder on me with the ebay header, but not too bad. i change my oil without lifting my car, i just park the front pointing downward.
Old 10-10-2006, 06:35 PM   #7 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Latex gloves and gojo are helpful to have around the house.
diver9000 is offline   Reply With Quote
Old 10-10-2006, 08:47 PM   #8 (permalink)
CCC-norchap
sportrally88's Avatar
View sportrally88's Photo Gallery
i go from the bottom!......no jacks.....real fast ....while car is warm......7-9 minutes tops
sportrally88 is offline   Reply With Quote
Old 10-10-2006, 09:05 PM   #9 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
In my 101.. its fairly easy, ramps, drain oil, and you reach the filter from the top. Helps if the engine is cold though since the oil filter is like 4 inches from the exhaust.
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 10-10-2006, 09:20 PM   #10 (permalink)
diver9000's Avatar
Regardless of your body size, you should be able to do the oil change without putting it on ramps. Do the filter from the top and the drain plug isnt that far under to need ramps. 10 minutes on a bad day. Do yourself a favor and buy an oil filter socket. Its worth it if the filter is that hard for you to remove.
Old 10-10-2006, 09:31 PM   #11 (permalink)
Bitter's Avatar
ditto, i can change my oil myself faster than a jiffy lube could.
Old 10-11-2006, 02:00 AM   #12 (permalink)
View KKJR's Photo Gallery
Throw a bunch of rubber band on it and turn it by hand. Unless you tighten it way too much last time, you should be able to get it off easily.
KKJR is offline   Reply With Quote
Old 10-11-2006, 10:32 AM   #13 (permalink)
Amber's Avatar
View Amber's Photo Gallery
Oil changes are so easy ... even a girl can do it. Me!
2004 Corolla LE - 5 speed, leather, sunroof, spoiler, fog lights, alloy wheels
600 Mile Club - Founding Member
My FD - 335 hp - ~2800 lbs with me in it!
Amber is offline   Reply With Quote
Old 10-11-2006, 11:49 AM   #14 (permalink)
Registered User
Raddman's Avatar
USA
I bet
Old 10-12-2006, 12:18 AM   #15 (permalink)
View rice's Photo Gallery
Originally Posted by Raddman
I bet
calm down sparky.......
only 2 hours? when i first did mine for the first time, it took me 1 and 1/2 days
glad everything worked out for you though
rice is offline   Reply With Quote
first oil change today... twheat 2nd Generation (2005+) 11 09-10-2006 09:05 AM
Changing Oil tomorrow any suggestions? cephasiii 2nd Generation (2005+) 17 11-17-2005 09:45 PM
changing to synthetic oil? rice Archived Corolla threads 17 08-03-2005 09:33 PM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 12:36 PM
Had some fun with my AE92 today ;D Flashmn Archived Corolla threads 5 12-22-2002 02:38 PM
